2020 ram exhaust manifold bolts preventative maintenance ?
jeffro2011
Wisconsin
So my exhaust manifold on my 2020 Ram Laramie with 35k miles is fine, but I know in the near future the bolts will rust off and break. Wondering if it’s worth my time to replace the bolts now before I have to try to extract broken bolts in the future? Any input?
sticknrudder
SW MI
2020 Classic
I am wondering the same thing with my 2020 Ram. Has anyone had any success swapping them out with a better bolt and maybe some anti-seize before there is a problem?
If the manifolds have been heat cycled and seasoned for a few years,take them off and either sand them flat or have them machined flat,use Remflex 6022 gaskets and new bolts,and odds are they'll never give you any issues.But you need to remove them,and get them as flat as possible,before installing new bolts and gaskets.
If you don't have any broken bolts,nows the time to do it,before you have to weld nuts to broke off bolts
skates15
Ohio
Same advice for 2023 5.7?
sticknrudder
SW MI
2020 Classic
So is the idea you pull them off after they’ve warped a little and they just stay in that shape the rest of the life of the truck?
UncleDuck11B
