Come on crash... payload police or not 10K on a Limited will go over the GVAR and that is "dangerous"10K is that the GVWR of the trailer? or actual loaded weight? Either way that's a whole lot of trailer to have behind a 1500. The fact your asking tells me you don't have much experience pulling heavy.
It will definitely take some extra paying attention to details for an RV that heavy. Depending on how the load is situated, it's a 1K minimum on the tongue, having a WDH adjusted correctly will be a must even for a 2500.
Now we'll hear from the payload police tell you how everyone is going to die if you tow that and even your great grand children will be sued for everything they're worth..smh
Not necessarily, all comes down to where the weight is loaded and how it's hitched. Even if the truck has a 1300 lbs payload doesn't mean he'll be over GAWR and he could be right up to the line in the sand with the GVWR. The GAWRs added up are more than the trucks GVWR, there is also safety factor in those rating numbers.10K on a Limited will go over the GVAR and that is "dangerous"
A limited will be lucky to have 1100lbs of payload,Not necessarily, all comes down to where the weight is loaded and how it's hitched. Even if the truck has a 1300 lbs payload doesn't mean he'll be over GAWR and he could be right up to the line in the sand with the GVWR. The GAWRs added up are more than the trucks GVWR, there is also safety factor in those rating numbers.
People have a bad habit of posting "no" comments without knowing the actual numbers.
Pictures? We need PicturesI just saw 2 Florida Highway Patrol vehicles pull over a Ram 1500 today. He was pulling a boat, and they were putting the scales under his rear tires, guess they are cracking down on overloaded towing
Wish I could have snapped a pic, but was driving in trafficPictures? We need Pictures
Your more likely to kill someone being complacent towing thinking since you have a HD truck everything is fine. W T H did I ever say towing 15K with a 1/2 is ok? Don't make stuff up, and don't assume cuz you know what that makes you.@crash68 just thinks everyone is ok towing 15,000lbs with a 1500. One of these days someone might follow his advice and get themselves killed
Not sure about FL but in NC boats fall under a different class than travel trailers. The tags are different for campers. Actually it is any other trailer than a camper. The rules are bigger than that but just sayingI just saw 2 Florida Highway Patrol vehicles pull over a Ram 1500 today. He was pulling a boat, and they were putting the scales under his rear tires, guess they are cracking down on overloaded towing
That's too bad. That picture would be an answer to a lot of questions on here. And cussing and discussingWish I could have snapped a pic, but was driving in traffic
