HK1837
Hi all. I asked this in my build thread but may have been missed by most.
I'm fitting a replacement front bar, which has 20W clear LED floods for the parkers and 40W Amber spots for the fog lights.
I have a spare bar with a harnesses in it, so I was going to cut the plugs (two for parkers and one for fog lights) and make up new harnesses so it all plugs into the factory harness.
I did some searching on the site about possible BCM problems with this, and found some possible information in post 28 of this thread below - is this all I will need to do? The two changes Snowblind indicates? Or will I need some resistors as well?
Here is the bar for interest's sake. The light bar is being done with a relay with the coil driven off the LH headlamp high beam wire.
AlphaRex looking for customers with errors
My lights have been installed for a week now and have been error free. I installed HID bulbs so I had to make that change with AlfaOBD. Sent from my iPhone using TapatalkAny pictures of the light output with the hids ? And which hids did you get? Sent from my SM-T387V using Tapatalk
www.ramforum.com
