Our new truck has about 800 miles on it. So it's still breaking in. Current mileage is 17.5 mpg which is lower than I would like. Here's the spec's.
2021 Laramie 4x4 Crewcab 5'7" bed
5.7L V8 HEMI MDS VVT Engine (no e-Torque)
Curb Weight: 5241 lbs.
Gross Vehicle Weight Rating: 7100 lbs. / Payload: 1860 lbs.
Max. Towing: 11320 lbs. / Gross Combined Weight Rating: 17000 lbs.
8–Speed Automatic 8HP75 Transmission
1st 4.71
2nd 3.14
3rd 2.10
4th 1.67
5th 1.29
6th 1.00
7th 0.84
8th 0.67
Reverse 3.30
3.92 Rear Axle Ratio
275/55R20 OWL All–Season Tires (Circumference 100.2", Width 10.8", Height 31.9")
In 8th Gear, the engine turns once for every 3.179 feet traveled.
=1/(0.67*3.92)*(100.2/12)
With a 3.92 Rear Axle Ratio at 75 mph, engine RPM is approx. 2076.
=(75/60)*(5280/3.179)
With a 3.21 Rear Axle Ratio, the truck would travel 22.12% further at 3.883 feet traveled.
=(1/(0.67*3.21))*(100.2/12)
With a 3.21 Rear Axle Ratio 75 mph, engine RPM would be approx. 1700.
=(75/60)*(5280/3.883)
To get the same travel distance with a 3.92 Rear Axle Ratio, the tire height would need to be increased to approx. 38.9".
A set of 320/75R20 tire would get you there, but I doubt the truck would have clearance for them without modification.
