As for modifications, I had several things in mind. I took all my Thuren goodies taken off my my 18 and I will be putting them on this truck in time. Probably when the weather dries up a bit. It'll get the 1/2" over stock Thuren front coils, their track bar, and the Fox front reservoirs and rear fox 2.0's I spoke with Andrew at Thuren and as of right now my truck has 5/8" of rake. Substancially less than my 18. He said my springs will probably raise the front 1/4" to 1/2" which will be perfect. If they don't raise the front and lower it I'm not quite sure what I'll do. So far I've done an Access original tonneau, OEM mud flaps, and the CJC intercooler guard. I'm tempted to order the Carli reservoir mounts but I'm unsure of the durability in salty conditions so if anyone has any opinions or experiences with that I'm all ears.
Note......... with regards to the missing top screw on the mud flap......that will go through metal which I need to drill. I opted not to as it secured fine by the rest of the bolts. I'd rather not drill a hole in my new truck.
