dylan7338
- Oct 19, 2024
- 3
- 0
- Location
- Boulder Colorado
- 2022
- 5.7 Hemi
https://youtube.com/shorts/_hMibpu7Jwc?si=wjg2I_qG7U99WYMi
I have a 2022 Ram 1500 Big Horn on a 6 inch Rough Country Vertex Coilover lift. After about 10k miles with the lift installed, I began to hear this strange noise when maneuvering at slow speeds. It seems to happen most often when parking, but I have been able to pin point the noise to when I am stationary in neutral or drive, while gently turning the wheel back and forth while applying moderate brake pressure. The noise also occurs in other instances while driving, but I figured out it will consistently happen when I do this. I have been to several 4x4 shops as well as two separate Ram dealerships, none of which have been able to fix this problem. Most recently I had all my control arms replaced under warranty, but the issue still persists. From the video I provided, I focus on the tie rods and power steering as it seems like this is where the noise is coming from, but I am completely lost on how to fix this issue. If anyone has any recommendations or advise it would be greatly appreciated.
