2022 Ram 1500 Interior & Exterior Lighting issue
Tc-tomi
USA
2022 1500 Bighorn
Penstar 3.6
Hello,
I am new to this forum, apologies if I am posting in the wrong place, just let me know if there is already a discussion on this as well.
I have a 2022 Ram 1500 Bighorn 3.6 with e torque, originally with halogen headlights
I installed some amazon LED's in interior and in the third brake light. And I did aftermarket headlights from Raxiom. They worked perfect with no issues for 2 years, then the interior lights started to flicker at random times all the time (truck on or off). The battery is original but holding proper voltages. Then a few months later each projector on the headlights started to dim until they were barely on and they started flickering while dim and then they went out.
The dealer claims everything is ok and it is the after market lights that are the issue. There were no loose grounds, unless I haven't checked a specific one, the battery terminals are tight too.
So I got Alpharex headlights to replace them and they worked fine for a few months until now they are slightly dim.
Any experience or suggestions with this issue?
T
Tc-tomi
USA
2022 1500 Bighorn
Penstar 3.6
Have you checked all the ground points?
Well I mentioned above find any loose grounds, but if someone has a diagram or known locations for grounds that are in specific places I could look for those too.
