2023 5.7L V8 HEMI MDS VVT eTorque Engine 3.21 Rear Axle Ratio
gwilburn
2024 1500 Limited Crew
Hemi 5.7 eTorque
Actually with the increase of 8 and 10 speeds, you're getting less and less choice. Toyota only offers one gear, GM offers one I think unless you get the "tow package" etc.
The 3.21 with the 8 speed, has a deeper first gear than the old 6 speed used in the ram with a 3.92 or 4.10. Think about that.
In fact, the 3.21 with the 8 speed has a deeper first gear than the Tundra's 6 speed with 4.30 gears. It also manages to have a taller final gear than the Tundra, so not only can it pull harder off the line it will have lower rpms on the highway. Win win.
If you read the OP's comment, you'll see that his "problem" is on the highway. The 3.21 will give you pretty much identical final gear ratios as the 3.92 on the highway.
The difference between the gears (WRT towing) is only from a dead stop. But OP isn't complaining about getting moving, he's complaining about power and rpms on the highway, rear axle ratio won't change that in the slightest.
If you study the chart below then you'll see what we're talking about. The chart contains the calculated final gear ratios if both trucs are travelling at 65 mph. The 3.21 cells in orange "match" the 3.92 cells in orange. Same with blue colors etc.
Note how the 3.21 in 6th gear at 65 mph has 2191 rpms, which is identical to the 3.92 in 7th gear at 65 mph at 2194 rpms.
I've seen this several times before... those figures being equal, does not mean they are "equal" when it comes to stress on the driveline. There is a reason MFG's offer lower gearing and that equates to higher towing capacities. That's all I'm saying.
The OP also said he doesn't go over 65 mph - in the case of the 3.21, he would almost never be in 8th gear (or would be in-and-out of it constantly). So it absolutely has something to do with highway speeds - especially on 2-lane rolling hills.
I've driven my Dad's 2019 with the 3.21 a lot. It is nicer running 75+ on the interstate. Other than that, I much prefer the 3.92. AND, there's almost no difference in MPG's between our trucks unless we are racing up and down the interstate all the time. He's 84 years old and his MPG is virtually the same as my truck.
As for Toyota Tundra - If you watch some of the towing tests, they had issues with soaring transmission temperatures using that fast rear end (3.31 I think) even with the 10-speed.
ramffml
ramforum
I've owned two Ram 5.7s with the 3.92s and there is no doubt under any driving scenarios the performance is greater. Except for fuel consumption.
The "any" is super incorrect. The chart above demonstrates this, and the math for it is:
Torque at the wheels = Engine Torque * tranmission gear ratio * axle ratio.
You can subsitute the axle ratio from 3.21 to 3.92, now you're making more torque right? Not so fast, if you drop a transmission gear in the 3.21 you can make up the difference.
That's why I used the egg carton example.
4 eggs * 3 cartons = 12 eggs: is the same as
3 eggs * 4 cartons = 12 eggs.
(replace "egg" with gears)
1 (trans gear) * 3.21 (rear axle) = 3.21: is the same as
0.82 (trans gear) * 3.92 (rear axle) = 3.2144
You guys are hyper focused on the second variable (rear axle gear), but it doesn't carry any more weight or meaning then the first variable (transmission gear). If you change both variables at the same time, then you can still get a torque multiplication factor of 3.21(44).
ramffml
ramforum
Only from a dead stop. That's not what we're discussing. OP's issue is on the highway.
I've towed 7000 pounds with my truck, which is rated for about 8100 or so. It has zero issues taking off from a dead stop even with the 3.21. Where I feel less strong is on a freeway on ramp, or passing semis on the freeway up a hill. Rear gear ratio isn't going to fix that.
The 3.21 will never tow heavy loads in 8th. Not sure what your argument is here. The numerical gear of the transmission is completely irrelevant, what matters is torque multiplication; how much are you multiplying the torque of the engine, at the wheels? And this is a factor of 2 variables: transmission gear ratio * rear axle ratio.
This is irrelvant. I'm not getting into an MPG discussion when this thread is talking about highway towing.
You should see all the rams that have transmission heating issues on this forum. That's across the board, 3.21 and 3.92. But guaranteed it's easier on the transmission for the 3.21 to tow in 6th vs the 3.92 in 7th/overdrive.
Dusty
Rochester, New York
I get your point, but the comparison is valid when the two axle ratios are compared at a steady state speed, each having the transmission in the gear with the similar ratio. And, yes, approximately the same amount of torque will be delivered to the rear wheels.
But in driving where the vehicle is constantly accelerating from a stop or from a mid-range speed, depending on throttle pressure the transmission will likely shift into the next higher gear sooner with the 3.92 ratio, making that comparison difficult.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build Date: 3 June 2018. Now at 92912 miles.
ramffml
ramforum
Regards,
Dusty
What my chart shows, is that the last 5 gear ratios the trucks use while towing, are nearly identical (close enough the differences don't matter).
What's your definition of "mid range"? Because first and second go by extremely fast in my truck, and once I'm in third there is no difference anymore. And again, my truck doesn't feel weak in first or second. That's actually where I feel the most power (as you'd expect, that's where the torque multiplication is highest). I don't need more power in the city in stop and go traffic at every stoplight. Where I feel the weakest is on an on-ramp (3rd or 4th, trying to go from 30 KM/h to 105 KM/h to safely merge on the freeway), or passing a semi up a hill; gear ratio won't change a thing there.
There are differences, and there are differences that actually matter. I keep coming back to the example of the v6 with the 3.92 being only 800 pounds or so short of the v8/3.21. That's the official tow rating difference. But now get in both trucks and tow 7000 pounds, I bet a years wages anyone towing back to back will say the v8 feels strong and the v6 feels like its ready to window the block.
The tow ratings don't tell you the whole story, yet we obsess over these numbers because we all want a single number that nicely simplifies everything for us in a way that we can understand. They can be useful, but many seem to think that towing experience can be reduced to a single number and nothing can be further from the truth.
gwilburn
Hemi 5.7 eTorque
I've seen other threads where you beat this drum until everyone just gives up... Evidently your opinion is the one-and-only truth... Almost 1/4th of my current Ram's 98,000 miles has been spent pulling a trailer.
So I give up... You are right and the Automotive Engineers and the rest of us are wrong.
You feel better now?
Let the OP decide.
ramffml
ramforum
Let the OP decide.
Don't be childish, I used math to prove my point, how about you do the same? Explain to the OP using math how his highway experience will improve with 3.92 gears.
Break it down into calculated torque at the wheels and how that improves on the highway for the OP by swapping his gears.
gwilburn
Hemi 5.7 eTorque
Childish?? Look in the mirror bud.
I already stated real world facts... there is more towing than just a freeking gear ratio chart!
Have YOU ever PERSONALLY towed a 6500 lb trailer with a Ram 1500 4x4 crew with a 3.92 rear end?? Have YOU ever PERSONALLY towed the same trailer with a 3.21??? I HAVE!!!
So, is the OP interested in mathematics or real world experience?? I know what I'd be interested in (and my degree is in Physics and Mathematics).
I apologize to the OP for the argument that followed offering my opinion and experience.
I'm DONE !!!!
ramffml
ramforum
I'm DONE !!!!
So... no math to support your assertions then?
That's OK, just don't argue like your opinion counts for more than actual calcuations showing how the torque at the wheel is pretty much identical in the city, on the on ramps, on the highway, passing truckers etc.
That's the beautiful thing about math, it trumps feelings (and memory) every time.
ramffml
ramforum
And by the way I never said you couldn't offer your opinion. That's what forums are for, the more the merrier.
But if you keep replying directly to me how my facts are wrong then you need to show using math how they're wrong.
