Just a minor nit pick, it's belt drive not chain. The belt is bathed constantly in oil and is designed to "get wet", and its a 200k mile change not a 100k mile. Which means you probably only have to change it once in the lifetime of the truck. People freak out about this fact but its a minor inconvenience as far as I'm concerned. It's easy to plan and budget for, just the cost of doing business. If the rest of the truck/engine holds up its well worth the change at 180k (just to be safe).
You're referring to the variable OIL pump which is belt drive and has a service life of 150k miles.
The high pressure fuel pump I pictured above is CHAIN driven. The same chain that drives the camshaft through plastic guides and held tight by a tensioner. There's been failures around 120k and less. Typical fashion, just outside warranty.
It starts with a cam/crank sync code.
P0016 -- camshaft / crankshaft position correlation
I'll attach a picture so you can better understand. The belt is the lower one for the oil pump. The chain like I said drives the rest.
