22x14s
beasTEX
Venus, TX
Hemi 5.7 l
Okay guys need some help. I currently have a 6in zone off-road lift on my 2010 Dodge Ram. It's a 5 speed with 3.55s. I want to run 22x14 octanes with 35s. I would love to run 37s but of course I don't want to buy another tranny anytime soon since I have 3.55s right now. But I plan to regear later on down the road. Question is how much of a body lift do I need to add to clear 22x14s with 35s? And once I regear what will also clear 37s? And is my 5speed tranny a factor also? What would be a good gear ratio to swap with? How much would I be looking at to swap my gears?
jadocs
Wheel size is irrelevant if you're talking about height. 35's are 35's regardless of what wheel they are on. The only difference is the tire profile on 22's.
Wandell
Cummins 6.7
He wants to run 14 inch wide wheels, which is a huge issue. You will need more lift than someone running a 9 or 10 inch wide wheel. I think you should go ahead with a 3 inch body lift. Even with that, you may need to add a leveling kit or adjustable coilovers to fit 37's.
Rzrman328
The treeline
Ya I'm runnin 20x12 -44 and with a 6" alone, 37x13.5 were rubbing bad. I had to mod my lower valance and front bumper a bit and mold/push in my wheel wells. Pretty sure you'll be doin the same if not more.
beasTEX
beasTEX
Venus, TX
Hemi 5.7 l
Well I plan to run 35s starting out. So it would be 22x14s on 35s. Do yall think a 1.5 body lift with bils maxed out will clear it?
