iPunch
So I have been reading through the posts regarding tire size and how they affect effective gear ratio. The ram (2017 4x4) we bought came with 37x12.5x20 tires (3600 load capacity) with a 2" level kit. The problem is we have a 9600lb 32' TT that we are planning on pulling for a weekend or two less than 500 miles mostly flat (some foothills) round trip.
I understand the stress put on the transmission by doing this along with the stability loss due to sidewall flex isn't something that would make the current setup I have anywhere close to ideal for pulling a load.
The effective gear ratio that my truck has now is 3.31 or 3.37 i think. The two options I can come up with is either regearing both axles to 4.56 or buying some stock size tires to tow with. I just found a set of stock wheels with tires for $450 but they're 275/70/18's, but i think that would drastically change the looks of the truck.
Would changing my tire size to 35's be enough of a compromise to comfortably tow with or is that still going to be too much strain on the tranny for occasional towing?
