Ross Keierleber
I have a 2009 2wd, if I was to put a rear differential from a 3500 2wd dually under it, would it be the same as a 3500 for hauling and towing ?
No matter what you do to it, legally they go by the sticker inside the drivers door. So the answer is noI have a 2009 2wd, if I was to put a rear differential from a 3500 2wd dually under it, would it be the same as a 3500 for hauling and towing ?
