275/65 or 305/55
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
They didn't come with narrow thru tapped acorns? I would ask if they were supposed to be included as they are inexpensive.
You have center caps and the lugs wont be visible.
Cableman
Cableman
Longisland
No they didnt come with them, wasnt in the listing either. So i should just get cheap acorns with 60° angle?
BWL
Embrace the skeptisism
BC Canada
Do those wheels use the acorn style or the mag/flange style?. The stocks are all acorn, but most aftermarket are the mag/flange style. If the lugs fit, but not the socket go to a splined lug and get a spare socket just in case you split or lose one. I kept 1 in the truck and 1 in the tool box when I had that style.s-l1600.jpg lug_nut_types.jpg
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
oh i get it, i can take a challenger and mod the crap out it to beat a hellcat, then i should put hellcat badges on it just because ....great logic
If you can pull away from 392 challenger 5 speeds as well, just put an S in front of that R/T!
Cableman
Cableman
Longisland
From what i see online the open end lugs are ¾ or 19mm socket which fits in wheel, so i guess ill just order a set of those as a 6 point socket is more common in a pinch.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Make sure you don’t get the impact socket, it’ll rub on the bore and possibly chip your powder coat. A standard 3/4” with 1/2” drive will survive the rotations as long as you use a torque wrench to tighten to spec. Impact is fine to get off and snug
BWL
BC Canada
I have a set of each in my toolbox. The oe ooen ends I have are actually a slightly larger socket. 20200328_152916.jpg 20200328_152642.jpg
Cableman
Cableman
Longisland
I have a few regular sockets, ill pick one up for the glove box. Stock lugs are big, acorn part wouldn't even fit.
Cableman
Cableman
Longisland
Stock lugs are quite a bit larger then a ¾ acorn, but both have the same thread depth.
Still torque them the same at 130ft lb correct?
cam101
NC
Those wheels look good. I was going thru your thread and noticed the Helo wheels was an option. I just had some installed on my truck last week. Mine are the Helo 916s.
Cableman
Cableman
Longisland
Sweet, i was looking at those also but these came up for a great deal.
What size wheel ya go with, 29x9 ,20x10?
cam101
NC
I went with 20x9
Cableman
Cableman
Longisland
So i got convinced to go 305/55, i like em! Would have loved to seen 275/65s on these wheels also but i dont have a discount tire near me.
Rear sidewall is flush with top of flare, front is ¾" past.
They look so much wider than stock but really only 1" wider sidewall to sidewall.
So far I havnt seen any drop in mpgs and i think the ride is actually better!
Bilstein 5100s are in garage waiting for me to install but so far i have not rubbed any part of the wheel well.IMG_20200531_164422.jpg IMG_20200531_165543.jpg IMG_20200531_165559.jpg IMG_20200531_164345.jpg
