3.0L Hurricane Updates?
ramffml
ramforum
Maybe you should be looking at the engine you are touting. It's plagued with issues. Cam/Lifter failures, harness failures, valve failures. It's a Ford product. It's a p.o.s. on 4 wheels.
I'm aware it has some cam hardening issues but that appears to be a vendor/production flaw and limited to a few engines.
I don't buy into "brandx = pos". It really depends on the product (not the brand), and the features of that product. Ram doesn't strike me as all that high quality over Ford, I've been on this forum for 4 years and let me tell you that I have gotten very nervous at times with my current ride.
I wouldn't know which way to bet, hemi vs 7.3, cummins vs powerstroke; Seems to me there is no real solid choice, just loyal fans picking their choice of poison.
ThunderMug95
North Prince George, VA
What makes you think it's "wrung-to-within-an-inch-of-it's-life"? 500 HP for a turbo inline 6 is, well, no where near an inch of it's life. If it's built properly with forged internals, proper cooling and oiling, 500 HP is nothing.
Look at the 2JZ-GTE. People are getting 1500+ HP out of those 3.0 I6 turbo engines.
And who's to say the truck version won't be different? They could opt for an iron block, different turbo's, internals, cam profile and tuning to put out 450-475 HP and 450-475 ft/lbs, moving the torque to come on early like we'd want in a truck, while maintaining reliability.
That 3.0 liter is working a hell of a lot harder with more moving parts than a lumpy old V8. Just my thoughts. I am on Team Displacement. I want the 6.4 in the 1500. I will keep my tuned 5.7 and just make it better. As long as my chassis is good, I am keeping it.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
I think they're all decent, but you're playing the lottery to get a good one from any brand. I lost that lottery on a 2011 F150 Ecoboost. Truck was plagued with so many issues, which Ford refused to acknowledge and repair, that lead to a long legal battle to get the truck replaced. When they replaced the truck with a left over 2012 I immediately traded it on a 2013 Ram. Two 1500's and my current 2500 later and no issues, knock on wood. I've owned a couple Ford's and GMC's prior, so not a brand loyalist.
I wouldn't touch a modern diesel from any brand. They're all garbage that require deep pockets to keep running once out of warranty.
Ratman6161
Buffalo, MN
I hear ya I'm just tired of Ram sucking hind ti! to Ford and GM in the HD gas engine department. I'm just not a diesel engine fan and ready for Ram to step it up.
If you think Ram is "sucking hind tit" watch the TFL Truck towing tests on gas engine 2500's. The Ram 2500 they test actually beats the Chevy 6.6 gas even though theoreticallt y Chevy should be better as it has 36 more ft lbd of torque. May be due to the 6 sp transmission GM uses, but the Ram still wins against everything except the Ford 7.3. Also Ford has been doing turbo 6's for many years but still doesn't put them in the Super Duty even though the 3.5 ecoboost makes more torque than the 7.3. That should tell you something,
ramffml
ramforum
That's just the stupidity of TFL and how they test. And they've been called out on that test many, many times.
Yes the 6 speed in the GM sucks for towing, but nobody drives like how they tested that truck. Anybody else (sane) would have forced a downshift in the GM instead of letting it lug at 2700 RPMs or whatever it was.
At worst, what they encovered was a transmission tuning flaw. There is no way that GM is 3 minutes behind the Ram. But when you let a truck bog down and lug its way up the mountain, well that's what you get.
Ratman6161
Buffalo, MN
They are testing the truck as the manufacturer provided it and letting it do/work as the manufacturer programed it. If they shift manually they are test8ng how they drive it, not the way the manufacturer programmed it. They also come out and say many times in many videos that this is what they are doing and that in the real world they would manually shift it. But if they do that they aren't testing how well the trucks tow/haul mode does on its own.
Also, they are testing the whole truck so if their is a flaw in the transmission tuning, it wouldn't be revealed if they manually shift. In any such test you have to pay attention to what they say and what they are actually testing and of course apply a grain of salt if their scenario doesn't match theirs. For example in the mid-west I don't typically worry about climbing 11,000 foot mountain passes. When I occasionally go west I'll just go slow if I need to. Not perfect does not equal useless.
Blaine WA
6.7L
Is this your opinion or have you seen information on this?
I personally agree a 3.0L is a small engine for a heavy duty truck but the output numbers are impressive and I don’t see a big straight six fitti
Hopefully you are only talking "generally" about big sixes fitting in the RAM HD.
Especially since the CTD is really a "big six", both external dimensions and internal C.I.D.
Rbertalotto
Boston
6.4L
nothing will ever replace the power, torq, longevity and versatility of the modern V8. try as they will a 6cyl anything is still missing 2 cylinders!!
You could not be more misinformed.....Try to find a V8 in most if not all current over the road trailer trucks...All have straight 6 engines. Loads of real engineers on YouTube discussing why a straight six, for heavy applications, FAR outperforms a V8.....V8 is for horsepower...Straight 6 is for torque......
Rbertalotto
Boston
6.4L
Simply do a YouTube search for ..."why a straight 6 is better" and watch for hours!
turkeybird56
Central Texas
That said the whole thing with the twin turbsky's needs to be upgraded to a bigger single turbo in the trucks. to my knowledge they were supposed to be making 2 different Hurricanes for this purpose?? one with a single and the other with a twin. As this is a new option i dont know much about it. Think i will stick with my 5.7 HEMI a little longer till they at least get the "bugs" worked out of the system.
And Hey if anybody has information on this then don't be setting on it! information is power yes but inquiring minds want to know!!
Gonna run my mildly equipped early 2019 DT truck till the rims fall off, gorilla glue them back on and run the truck some more. Very happy with my non-E anything Hemi, works for me.
ramffml
ramforum
You're missing my point. Yes they uncovered a transmission tuning issue. But no, that 6.6 GM gasser is NOT 3 minutes slower up the eisenhower than the Ram 6.4 is. If you drive exactly as THEY do (like mindless morons with the pedal to the floor), perhaps. If you drive like you know what you're doing, then you can get that truck up the hill just as quick as the Ram depending on other factors like trim/weight, gear ratio etc.
Basic physics. The GM engine puts out more power to the ground than the 6.4 hemi does. If you force a downshift if/when you run into that transmission tuning issue, it will pull up the hill faster than the Ram. It's a mathematical certainty.
So again: the issue with the GM is not the engine, or the truck being some POS, it just needs a little tweak in the transmission. And I suspect with the new 10 speed for 2024, the GM will outrun the Ram by some amount now; more power, more gears, more ability to hold near-peak power in more situations.
ramffml
ramforum
I'm not an expert in engine design, but it's not always that simple. The new Ford v8 power stroke decimates all other 1 ton diesels in both hp AND torque, both the duramax (v8) and the cummins (straight six). Something like 1200+ lb/ft of torque.
Certain engine designs do lead to producing more torque, an undersquare engine like the GM 2.7 turbo and the cummins, but that's due to the length of the stroke and not the fact that it's a straight vs v.
But hey I'm happy to learn if I'm wrong, so ... fire away.
Riccochet
Inline 6's are naturally more balanced engines than V8's. Less stresses being applied internally lend to longer life. Which is mostly why CAT, Detroit, Cummins, Mack, Volvo, Mercedes all use inline 6's in their industrial engines. You don't see Powerstroke or Duramax engines in semi's for good reason.
JerryETX
JerryETX
Elgin, TX
Hemi 6.4- 3:73- 6 Speed
I have watched at least one of those 6.4 towing videos with Mr. Truck in the video and watched the 6.6 and you're right it didn't do well but now GM is putting 10 speeds. I don't know if that'll help but it should be an improvement in towing performance. We'll see. Ram doesn't have an answer to Ford though. Their 7.3 is strong for a gas engine. Yeah the ecoboost technically has more torque and tows really well (I put 80K miles on one) for a half ton but doesn't tow heavier loads (10k plus) as good as my 6.4 Hemi does. If those 7.3's weren't north of 60k for a middle of the road model I would be driving one and pulling my camper a lot easier than I do with my 6.4.
I'm not saying the 6.4 is a dog it's not a bad towing engine for a gas. It pulls my camper (10,500 lbs) fairly well until I hit any type of incline. I just think Ram can and should do better.
JerryETX
JerryETX
Elgin, TX
For sure.
Ratman6161
Buffalo, MN
Actually I just re-watched the video where they tested the 2020 Chevy with the Gas 6.6. You are incorrect on some things. At 11:52 in the video, they are at 5000 RPM and 30 MPH going up the pass. It had to get down slow enough (25 mph in the place I'm talking about) before it could downshift without over revving. At a similar point with the Ram where they were hitting 5000 RPM they were hitting between 40 and 45 MPH. That's a consequence of the Chevy having too big a jump between gears...which I'm assuming will be fixed with the 10 speed in the 2024's. But yes, in their current state, the Ram is faster regardless of who is driving if only because 40 > 30 and neither truck can shift down one more gear at that point.
Also, the Ram was NOT 3 minutes faster. It was 1 min, 14 sec faster. The three minutes is from the section of the Ram Video where they do a flashback to the F-250 with the 7.3L to show what they are comparing against. That's the truck (the Ford) that was 3 min faster. The times were Ford 8:42, Ram 10:29 and Chevy 11:53. One final point: They also lament that the Ram they had had the 3.73 rear end rather than the optional 4.10. With the Chevy's there is no option. The 3.73 is the only one available.
In any event, my discussion wasn't intended to generate a debate about TFL and their testing procedures but just to say that the Ram is not "sucking hind tit" (your words) and is competitive with anything but the Ford 7.3. I'm also not saying the Chevy or any other Truck is a "POS) (again, your words, not mine). I actually like Chevy's a lot and owned 2 GMC's before going with the Ram. I probably would have bought another GMC since going to the mountains would be a rarity for me, but a crew cab standard box Chevy or GMC 2500 will not fit in my garage (my previous 1500's did). So I definitely don't think the GM trucks are a "POS". Ill look forward to them testing a 24 Chevy with the 10 speed but I'm pleased with my Ram.
ramffml
ramforum
It wasn't me that said anything about "POS" or "ram sucking hind tit".
I will have to watch the video again, but I know for a fact that the chevy was lugging under 3000 RPMs for a fair amount of time. That's why so many people called them out for it. Unless we're talking different videos.
Gear ratio is completely irrelevant for this specific test. If the truck needs more power it will downshift. If it has more power than it needs it will upshift. Gear ratio does nothing for 8 - 10 speeds climbing a hill at 60 mph. If you were doing 0 to 30 pulls with a ton of weight behind you, different story.
Ratman6161
Buffalo, MN
It will downshift...unless downshifting would cause the engine to exceed its red line.
