Boosted made one.I think they missed the boat by not dropping a Hellcat engine and transmission into a regular cab shortbox 4X4.They'd of sold every one they made,lol
There's a few Hellcat swapped trucks running around,but it's not a cheap swap.A Canadian dealership in Ont actually did the first one way back in 16,the truck has shown up for sale a couple times since they built and sold it,but i've lost track of where it is now,or if it's even running still. Up till Covid a local dealership about 30 miles from me,was swapping 6.4's into trucks and the smaller Jeep,the one that the 3.6 is the big motor in. My local Ford dealer has put whipples on a few of their regular cab shortbox trucks,and will install a whipple on any new 5.0 truck if you have deep enough pockets. There's still the odd dealer that will build one-off vehicles,you just have to find them,and use your big check book,lolBoosted made one.
It cost him north of $35k for the swap as well, plus a lot of time making harnesses and chasing down all the quirks that come along with the swap and fixing those. In the end, it's awesome but he warned me that if I ever considered it, to just be prepared.Boosted made one.
I say bring back the Magnum 5.9L...
Those things ran into the 200K mark with little more than a tune-up...
It bothers me more that they called these new engine's Hemi's. They aren't. They're more of an evolution of the magnum/LA than anything else.True, but they were dogs and sucked gas like a pig. If Chrysler had designed the lube system correctly on Gen III Hemi, we wouldn't have any gripes. Yeah, the exhaust bolts suck, but that's not a destructive loss of vehicle failure. More like nuisance.
They could have made a modern DOHC, but leveraged Hemi legacy for marketing, instead of creating a new legacy. It worked, they sold tons of these things, but it's also too bad because the day has come where they're forced to start over instead of the time of their own choosing. American corporate executives suck.
They started designing this iteration of Hemi back in either 98 or 99 if i remember right,and by then overhead cams were common,so they could of easily got rid of the cam in block design they used,and put a decent set of overhead cam heads on it,and had a hell'va power house engine,that would of bypassed the oiling issues. The 5.7's also started to have more cam/lifter issues after they moved the cam tunnel up farther in 08 to accomodate the VVT system,prior to that there were very few issues in regards to the lifters,although the heads had an issue with dropping valve seats if you overheated the engine.They fixed the valve seat issue,but seemed to have created the cam/lifter issue by moving the cam farther up in the block,putting the cam farther away from crank splash,and further compounding the issue by blocking alot of crank splash to the cam with the VVT tunnelTrue, but they were dogs and sucked gas like a pig. If Chrysler had designed the lube system correctly on Gen III Hemi, we wouldn't have any gripes. Yeah, the exhaust bolts suck, but that's not a destructive loss of vehicle failure. More like nuisance.
I'm gonna go with the politically correct "no comment" I watched my wife drive up the street earlier today with our 300C,and not only were the back tires spinning ,i'm pretty sure it was at 5500 when it made the 1-2 shiftHow many of you routinely operate your truck above 5,000 rpm? Case closed.
This info is all searchable on the interweb, btw.
The girl has a heavier foot then me
Bingo! You’re not the only oneI'm about low end grunt without all the diesel exhaust aftertreatment, like an everyday HD contractor. They're making it impossible to get now.
And no, I don't want a locomotive traction trolley motor with 8 tons of fire hazard batteries.
Hi y'all! Just wanted to let you know that I had the misfortune to drive a '23 Wagoneer with the new super engine - the HURRICANE!!!! Yaaaay!
I have 2 Rams. A '13 Tradesman with the 4.7 in a quad cab and a '21 Laramie Sport with the 5.7.
The new super engine took off ALMOST as fast as my '13. And it has 280K miles on it. What a POS TURKEY that thing is. 450HP MY ASS! 4.5HP MAYBE.
By contrast, my '21 took off like a scalded ape and I thought I was going to have to go back and pick my teeth up off the street!
God, I love that 5.7! AND YOU DAMN EUROPEANS NEED TO GO BACK TO EUROPE AND MAKE YOUR LITTLE 4 CYL GO CARTS!
My '21 1500 Laramie Sport has the 5.7 Hemi which has only 395HP, yet when I hit the gas, it takes off like a shot. Quite unlike the "Hurricane" I6 with supposedly 420HP.The Wagoneer has the standard output 3.0 with 420 HP. Then take in to account tuning for comfort, not raw power.
Go drive the Grand Wagoneer with 510 HP. It's a fat pig of SUV at like 7000 lbs, but it moves. A hell of a lot faster than my 6.4 2500.
No matter HOW it's tuned, 420HP SHOULD be able to get up to speed quite a bit faster than the I6 that sort of meanders along until it gets up to speed. 0-60 in 3.7 HRS! YEEHAW!!!
Torque management plays a big role in how much power gets to the axles.What a POS TURKEY that thing is. 450HP MY ASS! 4.5HP MAYBE.
