RamItFaster
- Jul 20, 2019
- 64
- 43
- Location
- Oakland Oregon
- 2018 2500 Tradesman
- Cummins
This a decent rear end gear ratio? Problems? Issues while towing or daily driving?
I have 3:42's in my 3500 SRW, that is the only option BTW. Truck is rated to pull just over 17,000 pounds, the most weight I've pulled is a 15,000-pound fifth wheel. I have no complaints, plenty of power and I can very easily make 65 MPH on the freeway acceleration ramp.
My 2500 has the 3.42/68RFE/Cummins TD... no issues and no problems, whether unladen or pulling four tons of travel trailer with power to spare. If I wanted to pull a lot more weight (i.e., a bulldozer on a flatbed trailer, I would go for a larger (>3500) truck before re-engineering axle ratios.
3.42's have no place behind the Cummins!! IMO Yes they are good for fuel mileage empty on the highway but otherwise 4.10's are the way to go!!! There's a reason FCA has gone back to 3.73's and 4.10's in the 19+...…. Drive a 4.10 Cummins and you will know why I say this!!!
Eggs, Zachary... and mine (2017, 6'4" box, CTD, 68RFE) is one of them. I have been pulling an ~8,000# travel trailer (with the truck loaded, too) on all sorts of hills and level ground. Never had any problems... not even any issues.There are posts in this thread that are different than your opinion. To say 3:42s have no place behind a Cummins is not true. There are 10's of thousands of RAM HD's with 3:42's running America's highways pulling all sorts of things, successfully.
My Opinion!! I did not say they can't do it, I just don't think they do it well!! I have had trucks with 3.42's,3.73's and 4.10's and just like the way 4.10's gears keep the cummins RPM's in the sweet spot. Also Summit1 8,000 lbs. is nothing for these trucks!! A half ton would pull that weight just fine!!!LOLThere are posts in this thread that are different than your opinion. To say 3:42s have no place behind a Cummins is not true. There are 10's of thousands of RAM HD's with 3:42's running America's highways pulling all sorts of things, successfully.
the guys that swore pulling a 5er without a dually truck was an absolute **** show when I was looking for my Cummins. Get real
Sweet spot!? With my stock size 33" tires 4.10 gears would put me at 2720 rpm. That's at the very end of the torque curve. No need to turn that high rpm. That is hardly the "sweet spot" for the 6.7 Cumins.My Opinion!! I did not say they can't do it, I just don't think they do it well!! I have had trucks with 3.42's,3.73's and 4.10's and just like the way 4.10's gears keep the cummins RPM's in the sweet spot. Also Summit1 8,000 lbs. is nothing for these trucks!! A half ton would pull that weight just fine!!!LOL
