3.55 Rear End Finally Giving Way?
Dusty
Rochester, New York
How to Diagnose Axle & Differential Noise
Warm the axle and differential components and fluid by driving the vehicle at least ten miles.
Growling or whine noise that occurs only at a specific speed range (straight-ahead driving)​
On a straight, smooth and level road, bring the vehicle past the speed that produces the noise. Shift the vehicle out of gear and coast down through the speed range where the noise is usually heard. If the noise stops or changes significantly:
Low or insufficient differential lubricant
Expired or contaminated differential lubricant; incorrect viscosity or lubricant
Incorrect ring gear backlash
Incorrect pinion depth
Incorrect pinion-to-ring gear tooth contact
Worn or damaged front pinion bearing
Damaged ring or pinion gear teeth
Incorrect carrier housing offset or squareness
NOTE: Noise in a specific speed range can also be initiated during acceleration or light load constant speed.
On a straight, smooth and level road, load the differential by accelerating the vehicle:
If noise occurs, the rear pinion bearing is defective
On a straight, smooth and level road, unload the differential by coasting the vehicle:
If noise occurs, the front pinion bearing is defective
Constant Noise (any speed)
Worn or damage pinion bearings
Worn or damaged differential bearings
Worn or damaged axle bearings
Noise occurs on turns only​
Worn or damaged differential side gears or thrust washers
Worn differential bearings or thrust washers
Worn axle bearings
Vibration
Defective or out-of-balance tire(s)
Damaged, bent or out-of-balanced wheels
Damaged or bent drive shaft
Out-of-balance driveshaft (missing weights)
Loose or unevenly torqued wheel lug nuts
Worn U-joints
Weak coils or loose or broken rear spring leaves
Damaged axle shaft bearings
Loose pinion gear retaining nut
Excessive pinion yoke run-out
Bent axle shaft(s)
Low Speed Knock​
Worn U-joint
Worn side gears or side gear thrust washers
Worn pinion shaft bore in the carrier housing
Driveline Snap -Clunk or Snap sound when vehicle placed into Gear,
Clunk or snap when changing gears
High engine idle speed
Transmission shift operation (automatic)
Transmission shift operation (manual – operator)
Loose engine, transmission, or transfer case mounts
Worn U-joints
Loose spring mounts
Loose pinion gear nut and yoke
___________________________________________________________________
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 74378 miles
TheEnder
TheEnder
4.7L V8
Worn axle bearings
Vibration
Worn U-joints
Bent axle shaft(s)
Low Speed Knock​
Worn U-joint
Worn U-joints
Loose spring mounts
Regards,
Dusty
The fluid was changed i think 50K miles ago. It may have been 40K though.
Status update: I took the rear diff cover off and found absolutely no metal anywhere and the fluid looks clean still. I lifted up the back end and threw the truck into drive and confirmed that the noise is coming from the rear end too.
Also, it may have been the wrong viscosity/damaged as i haven’t seen consistent answers on what the 3.55 takes. I tried the coasting method from 55 MPH and the noise nearly went completely away, still could hear it a tiny bit though. I wonder what’s going on. Pretty much nothing on the differential magnets too, just very small amounts of very fine material.
TheEnder
TheEnder
4.7L V8
Here’s a video of the sound. It’s not that loud in video but just imagine it 10x louder at cruising speed.
TheEnder
TheEnder
4.7L V8
I am going to try running solid Lucas HD Oil Stabilizer in the differential and see if it changes the sound. No harm no fowl if the differential is already shot.
You're 2013 diff will call for 75W-140
Midknight
New Jersey
I just had my 3.21 rear diff rebuilt. Had loud whine that was only getting worse. Replaced fluid first just to check and everything looked fine. Still had whine so took it to specialty diff shop near by. They test drove it and confirmed the rear needed work. Because of mileage they recommended replacing ring and pinion while in there. The gears were almost impossible to find so they let me hunt down the parts. I ended up just paying labor and providing a master rebuild kit, ring and pinion, axle bearings and seals. After the work was complete he stated the pinion bearing was shot, just grinding when turned. I was very happy with the work and am almost done with the 500 mile break in before doing the fluid change.
DILLIGAF
Canada
It takes a professional to set it & they use gauges
Dont sell yourself short. Its not that hard... lol... If My dumb*** can figured it out anybody can.
Its a driveway job, not heart surgery.
TheEnder
TheEnder
4.7L V8
Solved the issue.
Drained the fluid in the diff, came out so metallic i could paint a house with it.
Going in for service on the 29th.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
My 2013 had the same issue, turned out to be the Pinion Bearing.
TheEnder
TheEnder
4.7L V8
Truck is in for service now. Will let everyone know what’s happening tomorrow as they have to check & advise.
TheEnder
TheEnder
4.7L V8
Hello everyone,
Dealer got back to me yesterday on estimate and what is wrong. Dealer tech said that there were chunks of bearing material in the differential & that the magnet had chunks of the same material on it. Every *single* bearing was completely wiped out but somehow the case was still fine and in reusable shape. The estimate is $2196, but as since im not in any sort of shape to repair it myself i am going to let them handle it. Take this as a note to ALWAYS occasionally look under your vehicle once a month (or even once a week) for leaks coming out of anything. I got lazy and this happened. Still, first major failure this truck has ever had in the 10 years of ownership + it managed to tow a trailer near the tow rating of this truck with the rear end this bad.
huntergreen
Hello everyone,
So, a leak caused the failure ?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Hello everyone,
For that price just get it regeared to something better ... that is way too much man sorry, I wouldn't pay that especially at a dealership ....
Dodge 1500 4X4
Rochester, NY
Probably wiped out the pinion bearing, and it took out the axle bearings with the contaminated fluid.
I’m pretty sure, only thing i can think of that could. It wasn’t even that low, just maybe half a fingernail low.
Don't you have 200,000+ miles on the truck?
VLG6963
