Bluesurf
I have this engine in my GC Summit. It has been flawless with 57K miles on it. I never used my Lifetime MaxCare on the engine. However, I used it elsewhere. It has been a solid engine and performer.
Update: I have my truck back after 8 days. 3 recalls completed. I have a new transmission, condensor/trans cooler, evac and recharge of hvac. 3 yr 100k mile warranty on new trans. Tech notes said he found metal/brass in oil pan. The truck drove just as it did before minus the whine. I'll have to get under there tomorrow and inspect the work. I'm very happy with the service and outcome. I did buy the truck used with 21k miles. It's now at 29k with a new transmission.
Thanks for the update.
I don't think I've heard of maybe one other Pentastar Ram 8HP45 issues where transmission replacement was necessary. You read of more 8HP70 issues, but figure there's probably more Rams equipped with 70s out there.
Given the low mileage of your truck, it sounds like a manufacturing defect. Who knows. Transmissions boggle my mind how reliable they are given the amount of moving and electrical parts in them.
Just bought 2017 ram 1500 with pentastar 58000 miles apparently oil pump came apart so they replaced engine now having an issue with my
The oil temp gauge(s) will cut out while driving usually about 30 to 40 miles into a trip. When this happens if I give it enough throttle to hit around 4000 rpm the engine cuts out as if the govener kicked in. I have to get off the gas until it drops down to about 2000rpm before I can apply throttle again.
I have been getting a Major whining issue for awhile ! All I did was pop open the door and pushed her out :O FYI I was nice and slowed down to 25MPH before I pushed her out
lol
..... I almost wish I bought a Hemi just so I could be in on all those fun discussions!
The oil filter housing/cooler in our 2013 3.6 Pentastar Jeep Wrangler failed last week. I started to notice oil in the valley two weeks ago and it was running down the bell housing of the trans. The leak wasn't too bad but it was getting worse. About 76,000 miles on the clock. I believe it was the seals instead of cracks but who knows for sure. Replaced the oil filter housing/cooler, upper and lower intake seals and the spark plugs while it was all apart. The parts alone from the dealer here where $560.00 CAN plus tax. I pushed the easy button on this one. My wife's buddy owns his own garage and got all the MOPAR parts way cheaper than I could and put them in for slightly more than I would have paid for the parts alone.
Keep an eye for oil leaks in the valley under the intake if you have this motor in your truck. You will all be replacing this part soon enough.
Where were you able to see into the valley? I can’t find a good angle.
I ask as I have a hot or baking oil smell come in through the HVAC on occasion, but my 6000-8000km oil change interval never shows the loss of a drop. It’s really annoying me.
That whole assembly is frightening (and obscene ) looking to me, but for how many of them are out there now, the problems you hear are far and few between. The only oil filter housing related issue I've ever come across personally was with a friend/co-worker's 2016 Grand Cherokee. The dealer did an oil change and either forgot the O-ring for the cap or just plain left it loose. Either way, he lost a ton of oil within a few miles. They came to work and fixed it in the parking lot for him.
This housing is a Rube Goldberg design of the highest order. I like my 3.6 so much that if I must replace it I will. I won't complain if I can get 100k out of the original. I will do the next oil change as it does not look difficult and I will just snug it till it stops.
I think each motor should have its own thread to give owners awareness their particular motor.
So I am curious as to what problems 3.6 owners are having? I have only 8K on mine with no issues so far.
