- Jan 8, 2015
- 10,014
- 5,905
- Location
- St. Louis
- 2014
- 3.6 Pentastar
Air tube - essentially yes...keep the intake air as cool as possible. That is fiberglass wrap around it which I have since covered with the shiny foil duct tape and than wrapped that with black tape rated for engine bays.Thank you for the data logging offer. I will try to do as you have done and get the information for my vehicle.
I have cleaned the radiator and condenser. I cleaned them once before when I switched over to LED lighting with grill off. I cleaned them again when I deleted the AGS. Used the spray cleaner in a bug sprayer pump that I use for my home AC units. Spray on, it foams, wait ten minutes, rinse off type. The condenser looked pretty clean from the get go as I assume the AGS offers a degree of protection from excessive bug guts and debris.
Your data does dispel the belief that the e-fan is preset to switch on and off via a PCM program using only designated temperature points. As dynamic as you’ve found the system to be I wonder what other systems feed the PCM data. I remember reading some time ago a post in another thread that something in the AC system feeds info to the PCM for cooling commands. I dismissed it at the time and now can’t find the post.
I see your modified air tube. What is the goal of your experiment? Lower intake charge temps?
