3 codes come up
outdoorarmour
3.9L
driving yesterday and all of a sudden it seemed kinda like there was no power of hesitation when i tried to accelerate.
Codes on scanner:
P0351
P0753
P0743
Where should a i Start?
97 Dodge ram 1500 sport 2wd
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
P0351:
Ignition coil #1 Primary circuit - Peak primary circuit current not achieved with maximum dwell time
P0753: Trans. 3-4 shift sol/trans relay circuits - an open or shorted condition detected in the overdrive solenoid control circuit or Trans relay circuit in JTEC RE transmissions
P0743: Torque converter clutch solenoid/ trans relay circuits - An open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit
Sounds like you got a couple problems going on here, however it's possible the trans. codes are related to the coil code. It might be possible your coil is going out. I'm assuming the truck was hot when this happened, right? If so, that's a sign the coil is going out. They like to start crapping out when then start getting hot, but run fine when they're cold.
stevenmicheal
