Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
3 inch American Truck level install
Discussion in '3rd Gen DIY' started by Orange whip, Jun 10, 2021 at 2:05 PM.
  1. Orange whip
    Orange whip Junior Member
    52
    16
    May 6, 2021
    01606
    Ram Year:
    2005
    Engine:
    4.7
    I am going to do this job with my son, he has a 2005 ram 1500 quad cab 2wd. My question is on the coil. This truck does not have a full strut assembly but coil and separate shock set up. I will buy a coil spring tool. The guy on American truck doesn't use a coil spring tool to do this. Any tips on how to go about breaking down the coil and shock and then using that tool?
  2. CorDog009
    CorDog009 Senior Member
    43
    274
    55
    Mar 15, 2014
    East Texas
    Ram Year:
    2005
    Engine:
    I’d use some sort of coil spring compressors. I have a pair that mount on each side of the spring. I’ve found it easier to compress the spring with a jack under the lower a-arm and use the vehicle weight to help compress the spring instead of just using the compressors. Before compressing the spring, loosen the upper ball joint nut a turn or so and hit the knuckle with a big hammer to unseat the ball joint, just don’t remove it until the spring is compressed with a jack under the lower control arm. That’ll help with the top ball joint, not sure if you’re replacing the knuckle and need to remove it. The shock is the easiest part to remove.
Share This Page
