3" lift with 33s...
ClassicJoe
NC
I am debating on putting on a 3" lift, but will be keeping the 33s since I just bought them.
Does anybody have a photo so I can get an idea of whether or not it will look bad to have a 3" lift with 33s?
ClassicJoe
ClassicJoe
NC
2019 1500 Classic Big Horn 4wd Crew Cab 6'4" bed...
Honestly, I would likely go with 3" front spacer/2" back spacer. I know everybody hates spacers, but it works for me and what little "off-roading" I do...
Also, would the Mevotechs work with that setup, or would I need different UCAs?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Here you go ... all these have 3" or 3.5" lifts with 33s
Nick@GotExhaust
Preferred Vendor
SC
3" spacer is way too tall. That is going to cause issues, maybe not at first but it will for sure down the road in the near future.
How about doing bilstein 5100's and Zone UCA's? That will get you close to the front lift you want while keeping your geometry proper.
Also a 2" rear spacer is going drastically reduce the amount of down travel your rear shocks have. You really should run a longer shock. The Fox rear shocks will allow for 2" of lift and the Icon rear shocks will allow for up to 3" of lift. Also if interested the ICON rear coils will give you 1.5" of rear lift while offering better ride comfort and off road performance.
message me if we can help by offering more info and a quote.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
A clean look is 2" front 1" rear on 33's
2.5" and above is 35 territory
El_Lobo_Gris1500C
Canada
33’s May look a tad small with a 3” lift, depending on the tire design and how aggressive the side walls and biter pattern looks. On a 2-2.5” level kit the 33’s (which is a stock 20” tire size) look ok, ok like a factory set up that was levelled. Anything 3” lift and up looks much better with a slightly bigger tire like a 35” etc. IMO.
kurek
Northwest
Don't worry about how the tires are going to look.
I understand that you will disregard my advice but I'm going type it anyway. Spacers in front are how you get cracked front axle housings. Especially something nuts like 3 inch spacers. Has nothing to do with whether you go off road or not, unless you're driving on a NASCAR track you're going to flex the suspension entering parking lots and crossing railroad tracks.
Mevotech control arms do not have any offset built into them for raised ride height. Since your front upper and lower control arms are unequal length, wheel camber changes based on ride height. The alignment cams can't compensate for this above ~2" of net lift on stock or stock-replacement arms so if you lift over 2" you need lift specific control arms.
You get the results that you pay for. It's not necessary to put $5000 race shocks on the truck but there's nothing more expensive than buying junk that's too cheap to do the job right.
Bilsteins at 2.1" with stock upper control arms is the bang-for-your-buck champion here because you don't need new arms at that height.
MoparFin
U. S. Navy Vet - AS1
PA
I have an 18 quad cab. I lifted it with MotoFab spacers, 2 1/2" front 2" rear. I added the Mevotech TTX control arms, no issues with balljoints, stock arms the balljoints were popped out about 1/8" after a week. When I had it aligned, they were able to get it almost to stock specs. Rides fine, no abnormal tire wear and I have had the lift on for about 40000 miles. I have 275/65r20s on it, which are about 34".
RCSB guy
Nuevo Mexico
Hemi-5.7 with Pulsar
2.8” front (bilstein 5100)1.5“ rear (icon dual rate spring) on 295/70r17 (metric 33) on 2016 1500.
Atcer2018
Virginia
This is spot on advice. The Bilstein 5100 at 2.1 give a level more athletic stance to an otherwise stock 1500. No need for new UCAs, your alignments will be within spec and looks and ride quality are improved. You can even go with a 34 inch tire in the future. Nick @gotexhaust has great prices and the Bilsteins can be installed by the average DYIer in an afternoon if you want to save yourself some $$$.
kurek
Northwest
Here's my truck in 2015 with 33x10 (255/80R17) with the Mopar lift. That's Bilstein 5100's at first 2.8" then down to 2.1" in front, stock arms, rear lift coils (and some other parts not directly responsible for the height)
This is 2.8" in front ^ (remember the rear is lifted too, this is the full mopar 2" lift)
Below is 2.1" in front v
kurek
Northwest
Here is the same truck in 2020/2021 with 33x11 (285/70R17) tires, same approximate lift height but a bunch of changes to the discrete components the lift is made from.
This is with about 650 lbs of old logs and yard waste according to the scale at the transfer station
Justin33
Here is mine with a four inch superlift . I know you didn’t ask for four but gives you idea what it looks like with a 275 65 and four inch with a bracket lift.
healthyrx
Oviedo FL
2017 1500 Sport Night
Eibach Pro Truck Lift set at 2nd notch to get around 3.5" lift on stock tires and wheels (mine were about 33s)
Bone stock
joshuaeb09
Medina County, TX
I stepped down from my 315/70R17 Toyos to the stock Power Wagon sized 285/70R17 KO2s without changing my lift setup. So far I think it looks alright and it's been a lot better on the MPG/NVH side of things for all the highway driving I seem to be doing these past few months. Also got me just low enough to squeeze into a couple more parking garages that make my professional life so easier when I have to travel.
I had measurements while on the Toyo's + Kings combo posted in a thread somewhere, but sitting somewhere in the 2.5-2.75" of lift area (King's have settled a little). The flares do eat up a small amount of space making the gaps appear less so I image if I didn't have the flares it might look just a touch too small, but that's just my opinion.
