OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Location
- Philadelphia, Pa
- 2020
- Hemi 5.7L
*** THIS "KIT" I PUT TOGETHER HAS EVERYTHING YOU NEED TO SAFELY AND CORRECTLY WIRE UP A 32" LIGHT BAR AND 4 4" LED PODS! EVERYTHING YOU NEED IS IN THIS KIT!! WIRING, RELAYS, FUSES, ROCKER SWITCHES.. EVEN A FUSE BLOCK TO ADD ANOTHER LAYER OF PROTECTION!! YOU WILL NOT FIND ANOTHER "KIT" LIKE THIS ANYWHERE ONLINE. IF YOU WANT TO - PROPERLY AND SAFELY - INSTALL LED LIGHTS, THIS IS IT. DO IT RIGHT THE FIRST TIME!!! ***
I ordered all these lights and harnesses with the intention to put them on my 2006 Dodge Ram. After i placed my order, they were delivered while I was literally trading in my 2006 Ram for a 2012 Ram R/T. Certain circumstances forced me to trade in my truck, so now I need to sell this whole setup because my new R/T has a 5yr/100k mile warrenty and I don't want to put these on my new truck. My loss is your gain!!
All of these items are BRAND NEW and NEVER INSTALLED!! I only opened the boxes to check everything was right and to take pictures.
THIS IS OVER $280.00 WORTH OF LIGHTS, HARNESSES, SWITCHES AND BRACKETS!!!
If you go around the Web and individually buy each of these items, it's over $280. I'm asking $200 firm. I'm not willing to sell just one or two items, I'm selling it all as a whole lot.
*** $200 FIRM - NO SHIPPING - CALL OR TEXT JOHN AT 215-827-7252 ANYTIME ***
*** SPECS FOR EACH ITEM BELOW "ITEMS INCLUDED" LIST ***
- Items Included -
________________________________________________
• Senlips 32" inch 180W Curved Light Bar - Flood Beam /Spot Beam Combo - IP67 Waterproof
• (4) Auxbeam 4 Pcs 4" LED Light Pods - 18W LED Pod - CREE LED'S- Driving Light/Spot Beam - IP67 Waterproof
• MicTuning Wiring Harness For LED Light Bars & Pods - 30 Amp Fuse - 40A Relay - 180W Capacity - On/Off "LED LIGHT BAR" Rocker Switch Illuminated Blue (2 Leads/12Ft)
• MicTuning Wiring Harness For LED Light Bars & Pods - 30 Amp Fuse - 40A Relay - 180W Capacity - On/Off "SPOT LIGHTS" Rocker Switch Illuminated Blue (2 Leads/12Ft)
• MicTuning Wiring Harness For LED Light Bars & Pods - 30 Amp Fuse - 40A Relay - 180W Capacity - (2 Leads/12Ft)
• Mictuning Backlit Blue "FOG LIGHTS" Rocker Switch Kit- On/Off Blue LED Light - 20A - 12V Toggle
• MicTuning LED Illuminated 6-Way ATC/ATO Blade Fuse Block - 6-Circuit Fuse Block with Cover
• Rigid Industries 02-08 Dodge Ram 1500/2500/3500 LED Pod Fog Light Brackets For Lower Front Bumper
• (4) Dorman Universal 2 Terminal Male/Female Plugs To Make Custom Quick Connects And Sockets.
_________________________________________________
- SPECS -
Senlips 32" inch Curved Light Bar
Wide uses:
The Senlips led light bar can be used as emergency light, camping light, vehicle repairing light, field operation light and so on. The Senlips led light bar will bring you more convenience in your life.
Safe driving:
6000k color temperature and 13200LMS means you may have the clear view as in the noon, which will give you comfortable and safe driving.
Specification:
LED power: 180 W (60pcs 3W high intensity LEDS)
Voltage: 10-30 V
Beam type: combo beam.
LED color temperature: 6000K
Working life: 30000 hours
Working temperature: -40°C~85°C
Waterproof rate: IP67
Material: 6063 Diecast aluminum profile, aluminum bracket, PMMA Lens
Auxbeam 4" CREE LED Pods
Introduction:
High quality 6063 aluminum body, durable to withstand any harsh condition
Low current draw- no harms to battery and save gas
Longer valid irradiation distance than normal halogen bulb
Suitable vertical fins design for better cooling
Great performance of waterproof, dustproof, shockproof, anti-corrosion
Back housing and front cover can be separated, easy to dismantle and replace
Technical Specification:
LED Power: 18W
Number of chips: 6pcs 3w CREE chips
Operating Voltage: 10 ~ 30V
Lumen: 1800lm
Base Color: Black
Beam Type: 30 degree (Pencil beam pattern)
Working Temperature: -40 ~ 85 degree Celsius
Color Temperature: 6000K
Dimensions: 4 inch
Protection Rate: IP67
Material: 6063 aluminum profile, metal bracket, PC Lens
Life Span: 50000 H
Certified by CE & RoHs
MicTuning 12ft LED Lights Wiring Harnesses
MICTUNING MIC-B1003 wiring harness kit with 5 pin on/off rocker switch and easy to install.
Details Makes Perfect:adopt 16 Gauge flexible strand copper wire,up to 180 watt load capacity. It is universal fit for any 7" 10" 12" 20" 30" 40" light bars that is within 180w.
Great Construction:40A Power Relay & 30A Blade Fuse for multiple safety protection. With 2 lights output connections,it can hook with 2 led work light or 2 small watt led light bar and any else off road LEDs.
12FT Extendable Wiring Harness:more than 12ft of wiring from relay to lights that is plenty of length to put it where you want, NOT LIKE OTHERS' ONLY 10FT.
CAUTIONs:We recommend professional installation,pls let professinal installer to wire the harness kit; If let the wire short circuit,the harness would melt and even caught a fire,We suggest that wrap all exposed wire with electrical tape to avoid a short circuit; Pls make sure your light within power 180W, or it would got melt as well.
3 Full 12ft Wiring Harnesses are included. Each one has a separate Blue LED Rocker Switch; FOG LIGHTS, LED LIGHT BAR & SPOT LIGHTS are the 3 Rocker Switches included.
MicTuning 6-Way ATC/ATO Blade Fuse Block:
#10-32UNF common bus supplies power for 6 circuits, widely used in autos, eco-cars, modified cars, buses, subways, airplanes, tankers, ships, etc.
Unique LED Safety Indicator: the indicator light flashes red when the fuse is blown, super easy to check the troubleshooting.
Corrosion-resistant: tin-plating copper components, non-toxic and tasteless layer, good hardness and conductivity.
Clear PC Cover, Dustproof & Dampproof, easy to open by pressing the latch.DC 32V voltage, 30A output, 100A max. input, w/4x 5.5mm Mounting Holes, suitable for #10 screws, easy installation
_________________________________________________ (2) Male Universal 2 Pin Plug & (2) Female Universal 2 Pin Plug
Make your own wiring harness's and quick connect wires. Using these plugs, you can quickly and safely connect and disconnect your wires just like they were OEM.
Weather and Water Proof seal. No dirt, dust or water will get into the plug. Forms a air tight connection.
1 Positive + Wire and 1 Negative - Wire for each plug. Make sure to match your +/- on each end so when you connect the plug, the pins inside match.
Rigid Industries 02-08 Dodge Ram 1500/2500/3500 Brackets For LED Pod Fog Lights
****MORE IMAGES BELOW****
- Items Included -
- SPECS -
Wide uses:
Safe driving:
Specification:
Voltage: 10-30 V
Introduction:
LED Power: 18W
Lumen: 1800lm
Base Color: Black
Dimensions: 4 inch
Life Span: 50000 H
