- Mar 17, 2016
- 516
- 478
- 2020
- L6 Diesel HO
I have a short 6’4” standard bed. I bought a manual slider I’ve never used it in the slide position! Most any of the newer 2010 on up trailers with the curved front clear the cab no problem I’ve taken mine beyond 90 degrees with a slight up grade without issue
My previous truck was a 5.7 hemi My current truck is the 6.7 Cummins I can tell you the difference is night and day The diesel does not break a sweat climbing while the gas truck would shift down and slow down while screaming high rev’s
Also my fuel economy nearly doubled more than covering the higher fuel cost
So imho go with the diesel
Good luck
My friend with a 2020/1?? WolfPack 5th wheel and his 2021 Ram 2500 truck will now disagree with you as his camper and truck are in the shop for repairs. They colided because of uneven ground. An auto slider would not have allowed the contact.
Perhaps if on only travels from level home to prestine RV resorts, a slider is not needed. I used the autoslided onmy 2013 RAM 2500 short bed many times. Especially when traveling an I had to get in/out of rural fuel stations.
