3500 Rear Axle off center
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
Hey guys, I have a 2019 3500 SRW, I just noticed my rear axle is not centered. Difference of a half inch when measuring from frame to outside of tire. I haven’t read this one before. Anyone else have this issue? I’m taking it to the dealer next week to have it looked at.
Ricktara
Farmington NH
So on my 2019 2500 measuring from frame to outside of tires at top I have 13 5/8 on left side and 14 1/2 on right side for your reference.
RedneckHippy
RedneckHippy
Washington
6.4 Hemi w/ MDS
that’s even more difference than mine, have you talked to your dealer about it?
dexter
Banned
Call up a guy who does alignments before you speak with the dealer.
RedneckHippy
RedneckHippy
Washington
6.4 Hemi w/ MDS
Just curious why? It is a brand new truck, only a 1000 miles on it, it should be covered under warranty right? A guy shouldn’t have to live with a truck that’s got a tire sticking out a half inch further on one side than the other. Bad on me for not noticing before I bought it, but I didn’t think I’d have to make sure the factory got the axle centered under the truck.
Ricktara
Farmington NH
I have been in the auto dealer business for years. I learned years ago that the engineers are smarter than me and I certainly don’t think anything is wrong with mine. Measuring tire to frame and comparing side to side is a very arbitrary measurement. My truck runs straight down the road with no weird tire wear, so i am not looking for problems.
dexter
Banned
Warranty yes,
But ask a guy that does alignments first so if the dealer says its not an issue and the alignment guy says it is you know you have to press the dealer to repair it.
RedneckHippy
RedneckHippy
Washington
6.4 Hemi w/ MDS
Warranty yes,
Ok, thanks, I appreciate your input.
olyelr
Kewadin MI
Just a half inch? Seems normal to me. Is it tracking weird down the road? How about the difference from the fender or bedsides?
A half inch seems very minuscule to me. I have never measured mine, but I would be willing to bet most vehicles in general are this way. Who says the frame isnt designed to be shifted over on one side anyway?
olyelr
Kewadin MI
Maybe go to the dealer and measure a few more trucks on the lot. I reckon you will find slight variances on all of them.
olyelr
Kewadin MI
A 2500 has coils springs and a track bar, so it will shift side to side during suspension travel.
RedneckHippy
RedneckHippy
Washington
6.4 Hemi w/ MDS
Yeah, I’ll check around, it’s just obvious when you look at the tire sticking out from one side vs the other. The bed is already not centered with the cab, and if I try and make up for it by shifting the bed then will be even more off from the cab.
olyelr
Kewadin MI
The bed isnt even lined up with the cab? Hmmmm. Sounds like the truck may have got a little beat up in shipping or something...how could they let that go from the factory?
HDGoose
L6 Diesel HO
How does the drive shaft alignment look?
CG2742
Mesa
Maybe loosen the mounting bolts and move the bed over a bit. I did this for my cab as my driver side was 3/4” outside fender vs the other side.
RedneckHippy
RedneckHippy
Washington
6.4 Hemi w/ MDS
I would if that didn’t mean it would be even more out of alignment with my cab than it already was. I‘ve just decided to quit being picky about it and say **** it, it’s a truck.
crazy jerry
WY
check the leaf springs to see if theyre centered in the shackles. that may be the problem. also, you should try to find a more precise spot to measure besides the tire. they arent exact from one tire to the next and theres a radius at the edge which makes it difficult to get precise results. jack the rear up and pull off the tires then see if you can measure from the axle hub or brake rotor or something
