Tpearson515
Here is a picture of my 33x12.5r20 on stock 20x8's I'm using a 1.5 spacer. With out a spacer would be pretty tight. Being a 20x8 you may be able to because the tire isn't as stretched compared to a 20x8,Quick question, what are the dangers of running a 12.5 on the stock 20x8 rims? I have a 2014 ram express with a 4 inch lift. Would a 35x12.5r20 rub the upper control arm with stock rims? Or would I need spacers ?
I've had these tires for about 5k miles. No uneven wear. running tire pressure lower at 32psi
