35s or 33s?
bspeermint4
Im getting my 09 leveled and im wondering how big a tire I can fit without it rubbing? would I be able to fit 35s or have to go with 33s?
DohCanadian
Saskatchewan, Canada
You can do 35s. If your staying on the stock rims your going to need a 1/4 inch spacer though so you don't rub on the UCA.
I'd definitely go 35s, if you go 33s you'll regret not going bigger.
Gardenfan
Chetwynd, BC
Depends on the wheels you use, there should be a link in one of these subforums about fitment and offset etc. But if you went with a 2.5 inch lift 35s shouldn't be a problem, once again provided the right rim is selected or might rub at lock.
B
bspeermint4
I was just gonna level it and keep my stock 20s. What kind of spacer would I need?
