37/13.5/20 on -24 offset. Any rubbing?
Davidwalz3579
New Hampshire
Just bought 37/13.5/20 and have 20” wheels with a -24 offset. I’m currently running 325/60/20 Trail Hogs(35.4/13.1/20) with a good amount of clearance so before I have these mounted I want to know if anyone had to do some trimming with a similar set-up?
Also I have a Tyger front bumper so I have a ton of open space up front. My main concern is the back of the wheel wells.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Up front you shouldn't have any rubbing because of the new front bumper ... you should have clearance for days ... if you do have any it will be from the pinch welds
If you do you can easily do a NorCal mod on that, but you should be fine with a -24 offset ... that is what the shop owner recommended I go with if I wanted 38's or 40's on my truck so that I wouldn't rub, but I decided to stay with 37's but had to trim the front bumper and pinch welds a bit ...
Davidwalz3579
Davidwalz3579
New Hampshire
Awesome thank you. Yea that pinch weld is sticking out a bit. Looking forward to seeing how it turns out.
atreides
USA
My 37s rubbed the pinch welds as well and the lower pirtions ofnthe fender liners. I hammered the pinch welds flat and cut out the bottom of the fender liners since I'll be replacing them later on anyway.
Davidwalz3579
Davidwalz3579
New Hampshire
What offset wheels do you have?
2018 2wd
Nice! So if you didn’t have much trimming with -44, then I should be cool. LOL
Like the stance of your truck too!
On my build thread you can see how much I trimmed from the bumper mostly really .... I do have a 7" lift so that helped a lot
Thanks on the stance comment, I fawken love the way my truck sits ...
