37's Not Balancing
JB1
Houston, Texas
Sounds like you got a great price on the KM3’s, I look forward to seeing a few pics and a review
sm10
sm10
2016 Power Wagon
I hope that fixes the shake issue for you, if it doesn’t- I am really curious how those tires will respond to the vibration/shake. Give this a read some time.
I know you don’t have “ Death wobble” but it still is a very informative read.
https://www.thurenfabrication.com/tech/death-wobble-in-depth.html
Thank you for that! Definitely a good read. I sure hope its not related to any suspension parts, but if it is I wouldn't be too mad if it forces me to upgrade to some Thuren goodies. lol
RoadRamblerNJ
Knoxville, TN
392 Hemi
sm10
sm10
2016 Power Wagon
I finally got the KM3's on Friday. First impressions are great! Smooth and quiet. Height wise I can't tell a difference, but I'm pretty sure they measure .2" shorter than the STT. Width wise they are definitely narrower which I'm completely fine with since I NO LONGER HAVE ANY RUBBING! I now have an extra 1/4 turn gain in the steering wheel which makes a decent difference when parking. I put them to the test on Saturday as I went playing around behind Lake Pleasant. A lot of rocky terrain and steep hill climbs. I never used the lockers because it was nothing crazy, but never had a tire break lose. They also have really good lateral grip as I was trying to get them to break loose on some turns, but they kept the back end under control. So far I'm really happy with them. We'll see how they hold up over time.
Paul Kelley
Apple Valley Ca.
diesel
If you can find a tire shop that still has an old tire truing machine you will be amazed at how nice the tires will be. I get all my tires trued and most do not even need to be balanced
Vid S
Markham, Ontario
I'm running AMP 35" Terrain Grippers on my 2019 DS. I use beads and have no balancing issues.
RoadRamblerNJ
Knoxville, TN
392 Hemi
What was the exact size of those BFG KM3's. I thought I read they were 37's.
I have a '17 CCLB and I'd like to put those on it. I've had the K2's on my '09 1500 and liked them.
Do you think I can fit them with maybe just a level in front?
Ratket
Arizona-
37”s can fit on a 3/4 ton with Just a lvl, the only thing is the back spacing on the wheel.
champ198
Lebanon, TN
Discount couldn't balance my new Ridge Grapplers after 3 tries. I took the truck to an offroad shop that specialized in balancing big, heavy oversized tires. They nailed it. The offroad shop had a Hunter RoadForce Balancer. It is simply a matter of skill and knowledge when trying to fix out of balance issues.
pwjouster
South Florida
my Toyo 37x12.5-17 RTs mounted absolutely perfectly on a Hunter Road Force, and the ride quality over the 35 RTs is night and day after 20k miles on the 35s. He said he can never get Nittos to balance this well, and a big part of this is mounting the tire on the rim the correct way. My wheels have less then half the weight they did when the 35s were mounted.
The tires are marked with the lightest or heaviest side, and as such, the tire needs to be shifted on the Rim until you have an equally balanced set. If a tech cant Balance a Nitto or Toyo, it is because of inexperience. Occasionally a tire can be out of round, bit its never a whole set.
i cant believe it took me this long to get into the 37 club.
