392 Valve Covers
ct7212
Atlanta GA
Anyone tried to fit the 392 valve covers on the PW? I hate the look of all the plastic under the hood. If you have please post up some pics so the rest of us can see.
ct7212
ct7212
Atlanta GA
those come on the Durango, Challenger, and Charger SRT 392's. I was just hoping someone had put them on the PW since they all have the 6.4 Hemi.
Grand Mesa
The 6.4L Hemi is a heavy duty truck engine versus the 392 Hemi is a high performance car engine. Although, both are the same cubic inches, they aren't the same engine. They even recommend different oil weights. The heads aren't the same on both.
So if a car engine valve cover actually fits onto the cylinder head designed for a truck, does it still meet the technical requirements for the truck engine. That's another question.
For example, something similar to a valve cover is a differential cover. There are manufacturers of aftermarket rear differential covers which look really cool and protect off road better, but the material utilized may not dissipate the heat as well as the OEM. Also, their shape may not fling the lubricant onto the gears as well as the OEM.
https://www.ramforumz.com/archive/index.php/t-165672.html
R.D.J.
6.4 HEMI
I know nothing about the 6.4 car/non truck version, but i dont think thats actually a valve cover. Perhaps a cover over the valve cover? I dont see any access to spark plug tubes, ways to hold coils down. Someone who knows please inform me!
Grand Mesa
The original post is an engine valve wiring (harness) cover which covers over the valve cover to make it glitzy. It does look better covering the coils and wires. Sorry, I knew that cover shown in your original photo could never be a valve cover for a Hemi, but until today had no prior knowledge of a valve wiring cover. Someone else needs to determine whether or not it fits.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
^^Yep believe they are called half shells when you order a engine dress up kit. But if any body knows where we can get the half shells that will fit 6.4 HD for the 2500,,would be great to know. Also hemi half shells for the 02-05 5.7 1500 would be great. Both of these simply bolt on over our coil packs and wires.
HemiLonestar
MD
The term you are looking for is "coil cover" lol.
For example, something similar to a valve cover is a differential cover. There are manufacturers of aftermarket rear differential covers which look really cool and protect off road better, but the material utilized may not dissipate the heat as well as the OEM. Also, their shape may not fling the lubricate onto the gears as well as the OEM.
Ok...yes, truck engine vs hp car engine. While true the heads aren't the exact same spec-wise, they are the exact same design/architecture; externally every hemi engine within it's family is externally identical (03-08 5.7/06-10 6.1, 6.2's being the odd man out). As for valve covers (which the part referenced above is not), all 09+ 5.7 and 12+ 392's use the exact same double hump valve (for valve clearance) cover and are interchangeable (all 03-08 valve covers are physically interchangeable but need will vary on which ignition system is in place). Production wise only the 6.2's are different. The coil covers will fit, however they are only a straight bolt on to car and suv 392's. Other engines require trimming to fit. I had a set on my Charger:
They will pop right on to eagle car and truck engines because they all use the same fuel rails with the same spots for the support pieces and are all somewhat similarly shaped. How do I know this? Because I have one of each lol. This is what they look like put up to a 5.7 eagle truck manifold (someone a while back asked me for comparison pics):
They are all quite similar, with the truck manifold and the 392 manifold being the most similar and both superior to the stock eagle car intake being they are active intakes.
With the truck 6.4 being identical EXTERNALLY (yes yes, internal differences aplenty, we know) with the exception of the active intake IT has and the fact that it kicks off to the passenger side:
It basically looks like the others, same fuel rails. With trimming, these coil covers will fit right on. You even have a choice, you can get 392 ones or 6.4 ones, both are available.
MJockey
TENNESSE
Hemi 6.4L
imag3215-jpg.146427
Can you tell us which manifold is which in this photo? Thanks.
JB1
Houston, Texas
My guess:
Left is 6.4 car engine
Middle is 6.4 truck engine
Right is 5.7 car engine
McBroom
Denison Tx
Hemi 6.4L
My guess:
I don’t think the middle one is the HD truck intake. I say this because my intake and throttle body is at an angle (looking from the front of the engine) it is at like a 45* angle to the passenger side.
Blue Streak Pearl off-road
JB1
Houston, Texas
Hey I said it was a guess lol
Maybe the middle is the 5.7 truck then lol
Grand Mesa
Looking closely at the photo, the obvious large yellow writing marked on the right intake clearly states, "5.7 Hemi". I've fallen for this before, my guess that it's really a 6.4 Hemi truck intake disguised as a 5.7. The other two are for something else.
HemiLonestar
MD
imag3215-jpg.146427
My guess:
You guys are killing me...I even put a pic of a truck 6.4 in that post LMAO
Car 6.4/392, truck eagle 5.7, car eagle 5.7
Here it is again...:doh2:
dkvnqbj-jpg.146429
Reactions: JB1
Grand Mesa
The best thing about the Ram 6.4L intake manifold is that it's the only one of my four trucks that I have owned within the past 40 years which didn't come factory equipped with a slow and progressively worsening intake manifold gasket coolant leak. Fixed them all.
HemiLonestar
MD
Well...it's a dry manifold, so I imagine it wouldn't LMAO
Grand Mesa
Finally! A dry intake manifold is unbelievable!
