3GCustomz engine covers install
NJMOPAR
Older and faster
ELizabeth, NJ
Ordered the 3GCustomz bare steel covers with HEMI cutouts to jazz up my engine.
Taped off the HEMI cutout & the edges of the inserts (for better epoxy hold),
and after sanding some surface rust, used DuPont self-etching primer followed by their primer/sealer.
Sanding with 600, 800 & 1200 then 3 coats of VHT Chrysler Hemi Orange engine paint and Gloss Black for the inserts. Total time was 3 days with drying/sanding. Finished them with a coat of Carnuba wax.
Their epoxy was only enough for one insert, used JB Weld for the other.
Draped a pillowcase over them while installing so as not to scratch them. Right side was easy, left side I had to remove the Vararam, disconnect the brake booster hose & wiggle it in.
They're not an exact match with the Vararam lid, so I'm thinking of repainting it with the same VHT to match the covers. Pics are with & without the red strip lights I put on the underside of the intake.
Bare steel sanded & taped
Painted & waxed
Right side
Left side
Right lit up
Left lit up
Ohio5pt7
Ohio
I like it
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
NJMOPAR
NJMOPAR
Older and faster
ELizabeth, NJ
Thanks! They're actually pretty heavy, but I didn't want aluminum since I was painting them anyway.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Looks great!!
MADDOG
Living in a Firepit
Looks good!
I powdercoated the engine covers on my SRT8 which held up well to the heat and condition in that compartment.
