408 stroker idea
1SilverBullet2
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
rowdyram
magnum 5.9
Yes you can use thinner gasket to raise compression but it is usually less than .5 of a ratio point so not worth it in itself but if your pulling heads anyway why not?
Merc225hp
NA
truck
gas
I don't know what heads you have on your motor, but just me I would not be putting too much time or money into them if they are stock org heads or just a rebuilt head. If you say have the thicker cast head then go nuts and have fun. Try searching the web for the Mopar porting patterns for the Magnum heads, I had them at one time but long gone.
Have a look, 3.9/5.2/5.9 ENGINE - Cylinder Heads - HiPoTek
1SilverBullet2
1SilverBullet2
North Dakota
I have a set of Odessa Clearwater stock heads( newer casting). Reusing the old head bolts shouldn't be an issue right tho?
rowdyram
magnum 5.9
Its always good practice to replace head bolts but yours are not torque to yield so its not required.
I would have replaced them but your probably ok
1SilverBullet2
1SilverBullet2
North Dakota
At the time I thought they'd be fine but now I'm thinking maybe not so much lol. Yeah TTY I woulda replaced.
