turboguy327
- Sep 23, 2014
- 67
- 40
I'll be doing a write up with the rest of the steps once I get time to work on it some more. As for the wiring, I'm having a friend of mine assist with it since he is a lighting up-fitter for vehicles. Here is how the wiring should go:
-Power wire from light bar to switch inside cab
-Ground wire from light bar grounded to truck (hopefully to a bumper support)
-Main Power wire from switch to battery with inline fuse
-Switch grounded to truck inside cab
This will allow for me to use the light bar with the truck on and off since it will be able to access power at all times.
That's not the right way to do it. You want to use a relay. Make it safe and do it right.
