Sasha McDonald
needing some help with the tranny. Truck is a ‘97 Ram 1500 5.2L with a 46RE transmission. Has 94k mi on it. When I bought it, if I put it in drive after reverse, it would not shift to other gears as I drove. When I put it in reverse, then park, then drive, it would shift in drive like normal. I have been told to replace the solenoids, which I did and it didn’t do anything. Then I replaced both solenoids again, the speed sensor, and the 8 plug wiring system. I also pulled the valve body and installed a Sonnax sure cure. I installed an oversized transmission fluid pan as well. Now, after all the work it will not go in reverse at all. Drive and other gears work well. Shifts smooth, no noises and no noises when shifting. Hoping to get some help here to steer me in the right direction. Thanks!
