RichEss
Just wanted to share to those looking to make their 1500 drive and handle amazing. After much research and some trial and error, this is what I came up with:
Mine is a 16 Laramie CC with 5.7 and 3.92
Bilstein 5100 front (set at 2.1) and rear
Powerstop drilled and slotted brakes front and rear
Hankook AT3 275/60-20
Suspensionmaxx front sway bar links
Roadmaster 1 1/8" rear sway bar (comes with massive links and bushings)
1" billet spacers in rear (doesn't matter what brand)
Carli Track Bar drop bracket (from CJC Offroad)
Alignment
As many have posted before, give the Bilsteins about 2000 miles to break in, at first you will say WTF, this ride sucks, I considered taking them out but one day, when you least expect it, you will realize that it rides great. This setup gives it an incredibly firm (not hard) and stable ride. Virtually no body roll. Probably the single best thing was the rear sway bar. The stock setup is lame. You won't believe it's the same truck
Alignment
