beardoctane
Hello guys, new to the forums here. So I apologize if this should be posted elsewhere etc. With that being said, any/all help is greatly appreciated!
I have a 2016 Ram 1500 Laramie that comes stock with LED Tail Lights. I came across a good deal on the Morimoto Tail Led Tail Lights, as I already have the Morimoto Head Lights, and am trying make the lights match up. Now, as many of you already know where this discussion is going, I am looking for some help with creating a harness that will allow for the Morimoto tail lights to work with my current setup.
I did some bench testing, and here is what I determined for wire color coding: (if I'm incorrect on these, please let me know)
STOCK LED HARNESS: (harness that is actually connected to the stock tail light)
Has anyone actually created a harness for this type of setup, and if so, was it successful? I am looking to create my own and want to just confirm the wiring layout/configuration. I'm not a wiring expert but get the concept. Again, I am new to this model and am looking to come up with a solution because I've searched high & low and reached out to several harness companies with no luck at this time. There has to be a way lol
I have some wiring parts coming in tomorrow, so I will do some more testing and update my findings. Again, any input is welcomed!
~joe
- Black - Ground (-) (x2)
- Yellow - Running/Park (+)
- Purple - Reverse (+)
- Green - Turn Signal (+)
- White - Reverse (+)
- Blue - Running/Park (+)
- Red - Turn Signal (+)
~joe
