4th Gen OEM LED Taillight, Driver's side, black trim.
Status
Not open for further replies.
kad
Hudson Valley, NY
5.7L HEMI
Anyone got a 4th Gen OEM LED Taillight, Driver's side, black trim (68093081Ax) that they're willing to sell cheap? Needs to be in full working order.
Mine's got 3 of the 12 or so turn signal LEDs out and keeps triggering the Turn Signal Out warning and causing the indicator and mirror signal to hyper-flash.
-K
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I have one, but it was painted with the niteshade black to darken the lens.
kad
kad
Hudson Valley, NY
5.7L HEMI
Hmm... I see a number of sources (youtube of course) that say rubbing alcohol or gas will remove VHT Niteshade, with gas working better. Have you ever tried it by any chance?
-K
shadowhawk
Southeast WI
I did not try gas. The issue might be the clear on top of the vht
kad
kad
Hudson Valley, NY
5.7L HEMI
Supposedly takes that off too. I'm trying to decide if I want to take the chance. Money is very tight right now or I'd just buy a new one. How much you would want for it, shipped to NY zip 12603?
-K
shadowhawk
Southeast WI
Let me try removing the nite shade
shadowhawk
Southeast WI
does your right side work ok? I buggered my passenger light on a basketball pole; that's why I only have the left. I bought spyders but they don't seem to play well on my truck. I get hyperflash on my turn signals
kad
kad
Hudson Valley, NY
5.7L HEMI
Passenger side is fine, the problem is only with the drivers side (see below for what's wrong with it coursesty of my pathetic video editing skills)
Glad to know that about the Spyder lights, I was considering them as one of the "looks most like the OEM" aftermarket if I can't find an OEM light.
-K
shadowhawk
Southeast WI
the only thing I can see that really does the trick is to sand the clear and VHT off. I didn't find any good evidence gas or anything else solvent based would work without damaging the rest of the housing.
shadowhawk
Southeast WI
I got the clear and niteshade off, I think. It will require some additional care to gloss it back up.
well, it's nice and shiny now. Lot of work to take that dang niteshade off, and almost 1/3 bottle of acetone. I have to replace my wife's nail polish remover now :)
So, it can be done. I'm on the fence if I want to sell it though. They seem to only get about $100 a side from some recent sales here.
kad
kad
Hudson Valley, NY
5.7L HEMI
Good to know that it works.
A salvage yard one is going for anywhere from $85 (listed as "restored") to more than a new one, so that's probably not an unreasonable price point depending on condition.
-K
kad
kad
Hudson Valley, NY
5.7L HEMI
I found these on ebay- thy have both left and right. Appears to be a 3rd party OEM look-alike
https://www.ebay.com/itm/Tail-Light...k-Interior-Clear-Red-w-Bulb-CAPA/371497266303
Lol, yup. @OnSale had pointed them out to me, I bought one about 9:00 this morning after a possible deal for a good salvage yard one fell through. :) Thanks though!
And just to tease me, the one on the truck worked perfectly for half my trip to my sister's this morning and then started acting up again. I suspect a crack in the board that is reacting to temperature.
-K
OnSale
5th Gen Crew
Philadelphia, Pa
-K
Could be a loose solder/connection inside the housing. A good plastic knife and some plastic weld and 2-3 hours and you could have fixed it. But then again, most people don’t want to do that lol.
kad
kad
Hudson Valley, NY
5.7L HEMI
I may pop it in the oven one evening when my wife isn't home and heat it up enough to pull apart to see what the problem was, but I can't risk taking the truck off the road for that sort of repair attempt without a replacement to hand.
-K
OnSale
5th Gen Crew
Philadelphia, Pa
-K
You can not bake open the oem 13+ tails. They are not put together like headlights.
The only way to open them is to cut the back plastic housing on the backside of the taillight right along the line where it meets the red outer lens with a hot plastic knife and then you have to “plastic weld” the 2 pieces back together. Not very hard to do, it’s what RetroShop does with all of their taillights.
kad
kad
Hudson Valley, NY
5.7L HEMI
Good to know. I hadn't looked real closely, but it looked like there was sealant in between the two pieces when I had it out. There were also 4 screws, which would make sense to me for a sealant setup, but not really for a sonic welded setup. Unless they are just solvent welded together...
Anyhoot, since I've ordered a replacement I'm going to ask an admin to close this "wanted" thread.
When I get around to attempting to open/repair it I'll post over in the DIY or Lighting forums.
@MADDOG Can you close this thread please?
-K
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
I got a like new OEM pair I will sell you for a fair price. PM me if interested.
Status
1Popeye
