4th Gen Smartbeam Mirrors
Status
Not open for further replies.
HvyDuty
Perrysburg, OH
5.7L
45C41C43-661D-453D-BC4E-DD17434A509A.jpeg EF54024A-2BFA-4D6D-AB3F-8059D7839CD9.jpeg
For 2013-2016 (i ran it on my 2017, just removed the Bluetooth mics for aesthetics. You can pop yours in if you have a 2013-2016.
Gives you auto high beam capability with Alfaobd. Works great.
$100 shipped
kp4243
NC
Will you take $80 for the one with no cover?
H
HvyDuty
Perrysburg, OH
5.7L
2018 mirror sold to kp4243 2013-2016 mirror still available. $100 shipped
kp4243
NC
Hey just want to let you know the one I got from works good. Dimmer is perfect. Although there is something that won’t allow the high beam control to function properly. It turns off my high beams when on the only way I can use them is to flash. Pretty sure either I don’t have something switched on or the wiring is messed up somewhere. Any thoughts?
H
HvyDuty
Perrysburg, OH
5.7L
Did your Ram have the SOS mirror already and dual zone auto climate? Mine did just no auto high beam. So when I upgraded all I had to to was change settings in Alfaold worked perfect.
You may need to upgrade your a-pillar harness to the higher trim one if all your alfaobd settings are correct to add smart beams. Hope that helps
Status
joeyoliver45
