Learning
My ole girl finally either threw a rod bearing or broke the crank, was watching the harmonic balancer move up and down, so needles to say after 400,000 miles she gave up on me, btw she is a 99 ram 1500 4x4, so I purchased a 2000 ram 1500 4x4 with a 5.9 for a donor motor while iIrebuild the original, my question is, is there a difference in the wiring harness everything I read said the flex plate no biggie but the injectors on the 5.9 are different than the 5.2 obviously and the wiring harness is different so do I need to swap wiring harness also or just injector plug ends, I'm gonna use the 5.9 ecm so I don't have to flash my original just Google isn't very helpful
Thanks in advance
Thanks in advance
