Hemi will outlive the HO? Ah, yes the fear over turbos. I just did a story on a 200k mile Tundra with a turbocharged engine. I'm currently working on a story with a dozen Ford F-150 EcoBoost trucks with over 200k miles on them ranging in age from 2013 to today. They are for sale on Carfax and looking over the free reports, I'm not finding "turbos replaced" anywhere.
Specific points are anecdotes, not data. I find it funny that you chose the turbo tundra and are "proud" of the little 200k it absolutely should reach without issues, when you're the guy who has ran two stories of million mile v8 tundras. A years salary says those turbos don't hit 1 million miles (just as an example), and the rest of the engine won't last that long either.
Consider what Ford said,
on the record, with a TFL interview (paraphrasing): "we developed the 7.3 for our super dutys because the turbo engine ecoboosts would not handle the duty cycle".
Think about that. The 3.5 EB at 500 lb/ft is competitive with the 7.3, yet Ford, the queen of tiny turbos, knows they will not handle the duty cycle of a heavy duty truck.
On the other hand, we have the 5.7 hemi being used in the heavy duty 2500 for like a decade+.
All the heavy duty engines are cast iron block, naturally aspirated, high displacement, push rod v8s. They vary a little on other details, but there is a reason they are all built that way.
For durability, are you suggesting because he had a target to meet global emissions, he didn't give any consideration to life of the engine? Please tell me you are not.
There is no suggestion here, what I said was that engineers don't have the final say on whatever you get in terms of the final engine. I have not spoken to the man, but I would bet a years salary that if he was being honest and transparent he would have preferred to build a new, modern v8, instead of this small high strung turbo stuff.
The point is: he's told to design an engine around certain constraints, and those constraints don't mean they're building the best most reliable engine out there. These things are terribly complex and guaranteed are going to make it even harder for the back yard mechanic to work on vs the hemi.
And when it comes to emissions, you realize the hurricane with direct injection produces more of it than the hemi with port injection? That's a little bit of fine print for you that they never mention.
The HEMI is behind on HP and MPG with the competition moving to more efficient engines. GM's lineup, like you pointed out, is currently being worked on for new replacements. They realize the engines are becoming outdated.
That's not what I said either, please actually understand the points I'm making. We all pretty much agree that the 5.7 can use a replacement. However, it IS still competitive with the other v8's in the space (so it would still sell in high numbers), and secondly, there ARE still other v8's that are getting updated or replaced. The issue isn't that the hemi is getting replaced, the issue is that the hemi is not being replaced with a new modern v8. GM will be releasing new v8s. The ford v8 was just updated and we have no reason to think it won't continue to be updated either.
Final point with the "outdated". You got that terribly wrong as even Ram realizes (always did) that they need the hemi and are bringing it back for some time.
