5.7 hemi forged internals/engine tips
Proride86
Vernon,bc
whats every one using for forged internals for the 5.7 hemi also looking for any internal mods while I have the motor apart for running boost I want to push around 15psi boost should I buy a mds delete or just unplug them or?? I have a 6.1 crank and eagle heads off newer motor also wondering what injectors to run to handle that much fueling also how much boost can the stock plastic intake handle thanks for any input !!
HemiLonestar
MD
I think if you are asking these kinds of questions you should let someone else do the work. Did the 300 engine not work or did you blow that one up too?
Administrator
^^^ I'm with him
You asking questions about things to run more boost than most of the stock parts can't handle.
P
Proride86
Vernon,bc
yes ! for sure also cam shafts what cut how much lift??
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
For someone determined to run big hp on boost that is new to the game I would suggest a similar route to what I did. Buy a quality short block and piece it together with proven cnc heads. Depending on your ability, you can jump into the build at whatever level you are comfortable with. Going boost, a hellcrate motor is a good deal at $14k. My pieced together 392 stroker with a V7-sci/cog drive has cost more.
Johnsram
Milwaukee
Yeah, why reinvent the wheel? Blown crate motors are easy to get, proven, and will almost invariably cost less.
HemiLonestar
MD
Another point right there...how many cams do you think a 5.7 has....? You have a 2003...how ya gonna tune it?
HemiLonestar
MD
Then you want to relocate the radiator for some odd reason...
Redtruck-VA
Virginia
If you are going to retain a mopar stock type pcm you will want to switch to a 05 ram pcm for it's tuning capabilities. It still uses a 32T reluctor wheel. Buying crate motor or a built motor make sure it has a 32T reluctor or have a strategy for engine management.
P
Proride86
Vernon,bc
No this is a fully custom. built truck since I’m building doing the ford 9” and 4 link so I got time to see what she’s got so I tore into my motor that I bought that was Supozed to be built but they didn’t do the rods an pistons so I want to buy some good ones to run high boost also I am running a vortech supercharger so I wanted to run Cummins rads just cause i have them and and use the air to air was just wondering if other guys have done thanks
P
Proride86
Vernon,bc
I don’t need tunning it’s got a hole stand-alone computer thanks tho
Redtruck-VA
Virginia
Take your time and enjoy the build.. I've worked on mine for many years and have probably modded everything on it one time or another.
P
Proride86
Vernon,bc
Thanks for all the input I ordered Molnar rods and mahle forged pistons and a comp blower cam also a full arp stud kit And thinking about the roller rocker kit
Redtruck-VA
Virginia
All good pieces in anyones book...
