Jervis
Hello,
I have a 14 ram 2500 with the 5.7 hemi so no mds. A few months ago I developed a significant tick in the engine. Both manifolds had just been replaced so it was not a broken bolt.
I took it to the dealer for a second opinion thinking lifter problem. They confirmed my suspicion and thought it was stuck roller as well on the lifter and likely starting to wear cam.
So I took the engine apart and found the #1 intake lifter had a bad bearing but the roller was still spinning. It looks like the lifter shaft was worn as the roller was still spinning and not worn but there was about 0.05 - 0.06” of play in the lifter roller.
One of the other 16 had a small amount of play but hard to even detect. Could not feel any wear on the cam but the hardened wear surface had some visual uneven contact. Long story short decided to change cam and all the lifters. Went oem cam and lifters. Read somewhere that it was likely a bad batch of lifters that were supplied to ram from 2011–2015 or something like that.
Put the engine back together started it up and was misfiring. On 5 of 8 cylinders. Pulled the valve cover back off and Found I had incorrectly installed the #8 exhaust push rod.
Properly installed push rod retorqued rocker shaft and started truck. All good.
I have been driving the truck for the last month or so and everything works fine except i hear lifter tick again on start up. I wouldn’t be concerned if it was a second or two but it’s probably closer to a 30s to a minute. Almost like the top end isn’t getting oil right away.
It goes away after that. Oil pressure is good and I’m running pennzoil ultra synthetic 5w-20 with Mobil filter. Changed the oil after the first 500kms.
Again sorry for the long post but just curious if anyone else has any thoughts?
