5.7 v 6.1
gonzo1968
Az
I have been looking in to modifying my 5.7: Stroker, cam, heads and Whipple. Most shops gave me a quote, but the last shop I called offered to sell me a complete stock 6.1, harness, PCM. With better breathing heads and a forged bottom end, this sounds great. However, has anyone actually performed the swap? Is it worth it? What will I need?
Kotta390
If I remember correctly the 6.1 heads do not outflow the 5.7 eagle heads
nickpohlaandp
Lake Charles, LA
A stock 6.1 isn't going to outperform a built and blown 5.7. That's a no brainer. What are your goals?
charonblk07
Calgary, Ab
F1-A forged 349ci
Could you explain further.
It physically drops into place without issues, it's the computer that needs to be made happy and you need a good tuner who is familiar with the swap because the engine wiring harness is slightly different. The active intake solenoid needs to be deactivated and tuned out, the vvt solenoid needs writing out and camshaft timing needs to be rewritten to remove the timing retard/advance. A PCM swap from a 6.1 doesn't work in the trucks because the 6.1L uses a pcm/bcm/tcm combo, the truck runs everything through the PCM.
You also need to make sure you have the correct reluctor gear because there's two different ones available, 37 and 58 iirc.
gonzo1968
gonzo1968
Az
Thanks for the detailed info charonblk07. I will build my 5.7 instead.
huntergreen
Marine Corps Navy Badge
depending on the hp output, you will likely have to beef up the trans.
gonzo1968
gonzo1968
Az
Got in touch with a local shop. They will piece together a stroker kit, port the heads and source all of the necessary valvetrain. I will try to post pics and info as the build happens
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I'm looking forward to see what they come up with for you.
kg93
AZ
yeah what kind of specs are we talking? estimated power?
gonzo1968
gonzo1968
Az
He mentioned a K1 crank, CP pistons/Rods/Pins, Ferrea valves and a Lunati S/C cam. Depending when this gets done, I may be running N/A until the Whipple is available.
