bigdaddygb
Ok so I have a 1999 dodge ram 2500 4x4 with the 5.9L 360 gas motor. I just did plug, wires cap rotor, the camshaft pickup in the distributor ( puck with wire coming out of it under distributor cap) wired it according to TSB and even installed new wire separators, new coil, and new IAC on back of throttle body. Idles great no hissing or anything till i step on gas then i hear hissing but still idles great. Put it in gear and it bogs down like its getting flooded. I did a compression test and all are between 150-185 across all cylinders. I did do the intake manifold plenum gasket last year and it seems like everything I do to make it run better makes it worse. Any ideas guys would be helpful. Thanks.
p.s. I did install new fuel injectors and a fuel filter prior to doing the plugs and stuff and ran a fuel pressure test and it holds steady at 50psi even while in gear.
