dapepper9
- Feb 7, 2013
- 5,908
- 2,224
- Location
- Iowa/Nebraska Border
- 2001
- 5.9L V8
I would not touch the cam if i were you. Unless you're looking for more power but cam changes are gonna cost an extra few hundred dollars in tuning and wideband 02 to properly tune it.I have limited it down to the heads being cracked and the valves being caked in carbon. I did a running compression test about a week(ish) ago and can see that a couple cylinders have a bunch of overlap during the compression cycle, which I am thinking is why my cylinders have been having issues. So my plan is to swap heads, lifters, rockers, push rods, cam, and modify my TB.
I have run through all the wiring, swapped injectors 3 times, swapped Ignition coil, cap, rotor, pickup coil, ECU, plugs, and wires with no avail. So I've narrowed it down to just old age and needing to be refreshed/upgraded.
If you haven't taken it all apart yet, get some amsoil power foam or Mopar combustion chamber cleaner and use that. You may be surprised how much that does for you.
You can do mods if you're wanting to, I'm not saying don't do that lol. That would just make me a hypocrite lol. But, don't think that he's being cracked means they need changed. Maybe 10% of the factory heads in these trucks AREN'T cracked. It's just something they do and 99% of em don't see any kind of running difference from it.
You can go either way. If you want to mod it, go for it. If you just want it to run like it used to, try a chamber cleaning and go from there
