5+ drop
CzBlkExp
Installed 2/4 Mcg Deluxe kit just after I bought the truck, decided it wasn't low enough. Added Belltech 2" drop coils to the front. Also changed from the stock 275/60r20 (33") to 275/45r20 (29.7"). Rear I have spohn arms that I haven't installed yet and plan to cut the rear springs down at least another inch.
So relative to stock 2015 Black express I am dropped 5 inches up front and still have plenty of clearance. Ground clearance to the transmission crossmember is currently 6 1/2 inches.
razor1
St.Petersburg Fl
any lower and the ride quality gets very bad , specially in the rear.
Statcher1
Kentucky
Yeah you can go about another inch in the rear. Before you start suffering from major ride problems in the rear.
Otherwise the truck looks good.
charonblk07
Calgary, Ab
F1-A forged 349ci
At that height pay very close attention to your rear lower control arm, it will start bouncing off the upper arm frame mount. Your rear arm geometry is also pooched right now, you need to get the Spohn arms installed to deal with the pinion angle which I'm not surprised if you have a driveline vibration from. How is your rear axle sitting across the body? Pushed out to the passenger side any?
C
CzBlkExp
Thanks for the feedback, only driven 10-15 miles on it so far and no issues. Ride seems comparable to 2/4 drop. The spohn arms will correct the pinion angle and recenter the axle in the wheel openings. I am going to cut 1" out of the back and see how it sits I do like a little rake. I have a shop that will redo the lower control arm axle mounts if need be but I am trying to avoid it.
Current mods are
Mcguahy's front spindles
Belltech 2 inch drop springs up front
Mcguahy's 4 inch drop springs rear
Cheap muffler with black painted tips
Airraid intake
Hemifever 93 tune
Bakflip g2 cover
srt10 replica 20x9 wheels
Nexen N'fera 275/45r20 tires
Hellwig front sway bar
Hellwig rear sway bar
4 MB quart 8ich subs in custom sub box
MB quart amp to drive the subs
To be installed
Full set of Spohn adjustable rear arms
To be ordered when finances allow
Qa1 adjustable shocks
leather seat covers
razor1
St.Petersburg Fl
grab an adjustable panhard bar also, the axle should be to the pass side about 3/4" right now
C
CzBlkExp
I have the McG panhard relocation bracket installed so its still pretty well centered, I have the spohn adjustable panhard but it isn't installed.
I cut my rear springs 2 coils this morning but now I have a weird grinding noise when turning left. I rechecked all my rear suspension to make sure I didnt bind up the panhard bushings or the sway bar bushings but havent found the problem. Going to pull the front wheels off either tonight or in the morning when it isn't so hot outside to recheck the front sway bar bushings and ball joints.
BlkRamRt
SoCal
HEMI 5.7
do you have any pics to show how much the front wheel sticks out?
C
CzBlkExp
The tire stickout is actually less noticable than it was with just the spindles. I would say its probably about where it was stock.
C
CzBlkExp
Still having a noise when I make left turns. Jacked the front end up and gave the wheels a nice firm shake and didnt feel any play. Checked the rotors were moving freely and not binding or scraping on the dust shield. I did find the sway bar end links were a little loose (need to replace with the f-150 links), I guess I got in a hurry and torqued them down with the front suspension at droop instead of ride height. I don't hear anything just cycling the steering right to left when sitting still. Took it for a test drive and the noise is still there. I think it might be the driver side front bearing, because it does get louder the faster I go.
Anyone know a quick way to test the bearing other than a infrared temp probe?
R/T_Fire
Pleasant Grove
can you snap some sots of how the front A-arms sit. Also what bump stops are you using or are they still stock?
I am thinking of installing a mixed kit like you did but with a 1" Crown spring up front to get the a-arms closer to stock position but retain the 3"+ drop I have already
razor1
St.Petersburg Fl
check the heat shield next to the driveshaft around the gas tank. Mine was touching after lowering it.
C
CzBlkExp
Stock bump stops at the moment, I have the belltech bump stops but they aren't installed. These pics are with the rear end up on ramps so it's a little more compressed than normal ride height.
C
CzBlkExp
Thank you sir, that was the problem. I didn't grab a pic before but with the rear on ramps there was ~1/4 of clearance around the ring on the drive shaft. I guess with full weight and a little speed it was rubbing. I could see a little shine on the drive shaft ring where it was rubbing. I clearanced it a little with a pry bar and went for a test drive around the block.
BlkRamRt
SoCal
HEMI 5.7
Thanks for this pics. I thought they would stick out more. Nice looking truck BTW.
C
CzBlkExp
more pics
Original pics at the start of thread are with 4 inch drop coils in the back, these are after cutting 2 full coils off the McG 4 inch coils to give ~5 inch of drop. Currently 31 1/4 inches to wheel arch in the front and 33 1/4 inches in the back (with my tire/wheel combo). Still has ~6inches of minimum ground clearance at the lowest point on the body which is the transmission cross-member. 2 pics with the silver VW are the after cutting rear coil pics.
I will say towing or any substantial load is probably out of the question without air bags. About to go get it aligned now so I'll update if any issues pop up.
razor1
St.Petersburg Fl
glad it worked out for you, that is a disturbing noise on a first test drive.
