drocket77
So about 2 years ago I put a new shift solenoid in, and it fixed my problems. In December my truck just stopped moving while my wife was on her way to work. It was on the side of the road for 3 hours, and someone cut 1 of the cats out... yea... why not just take both! Well, I finally had some time to take a look. I put both new filters in, filled her back up, and still will not go. I have checked the parking brake, lifted all 4 wheels off the ground and put it in neutral and spun the drive shaft. It turns, and spins the wheels. If I start the truck and put it into gear, it feels like it goes into drive or reverse, but the drive shaft will not spin, it also feels like there is load but nothing spins. Here is a list of codes associated with the trans
P0734 Gear ratio error in 4th
P0760 OD Solenoid Control Circuit
P2706 MS Solenoid Circuit
P0735 Gear ratio error in 5th
P0733 Gear ratio error in 3rd
Than these turned up
P1524 Oil Pressure out of range- Cam Shaft advance/Retard disabled
P0521 Oil Pressure Sensor Performance.
It starts and idles fine, no smoke.....
I am hoping the trans is not toast. I have never done a trans, but am willing to do the rebuild myself. Another question would be, what is a good rebuild kit? I see them from $180-$870.
I know the solenoid code is there, but it is 2 years old, and was not doing what it did previously. Before it went bad last time, i was stuck in limp mode, this time its did not do that.
