545rfe transmission not liking the cold ?
Discussion in 'Engine & Performance' started by doug2013, Dec 1, 2016.
Sponsored By: Moe's Performance
  1. doug2013
    doug2013 Senior Member
    146
    32
    May 30, 2016
    Georgia
    Ram Year:
    2009 Dodge Ram 1500 Laramie
    Engine:
    I have a 2009 ram with the 5 speed and right she doesn't want to shift into 3rd or beyond the speed limit around post is 30mph and usually ill cruise around in 4th gear or 3rd overdrive at about 1200 rpm. its -20 F outside right now so at first i thought it was the cold. but i plug my truck on and it has a heating pad on the transmission pan. But after driving around thought for about 45 minutes the truck was saying the trans was still below 104 degrees which didn't seem right. Has anyone else had problems with the 5 speed transmission not liking the cold or being stubborn to shift.
  2. savage_46
    savage_46 Senior Member
    350
    138
    Mar 7, 2016
    Alaska
    Ram Year:
    Engine:
    Check your tranny cooler lines. They were problematic & pretty much guaranteed to leak on the earlier models. Low trans fluid can cause lots of different problems, usually starting with shift concerns.
  3. Mineralram
    Mineralram Senior Member
    45
    522
    134
    May 20, 2015
    Ram Year:
    Engine:
    shift solenoids were also a big issue also, my 2009 had 2 done within 2 years
    Sent from my SM-G930W8 using Tapatalk
  4. pickupman66
    pickupman66 Senior Member
    715
    145
    Dec 30, 2013
    Tennessee
    Ram Year:
    2009
    Engine:
    I will add that these transmissions do run pretty cool. if you have the extra trans cooler, that may also be a factor in its running temp.
    huntergreen likes this.
  5. doug2013
    146
    32
    May 30, 2016
    Georgia
    Ram Year:
    Engine:
    only have the factory cooler and there are no leaks trans is full of fluid didn't have a problem until the extreme weather. im going to try to block the radiator to store heat better maybe its not getting up to temp
  6. doug2013
    146
    32
    May 30, 2016
    Georgia
    Ram Year:
    Engine:
    Did you have any codes pop up ? my truck is running fine this morning i double checked the fluid cold and it could use half a quart. I might take the pan off and change the filter both in the trans and the inline filter in the cooler.
  7. RamCares
    RamCares Senior Member
    1,408
    692
    Jan 21, 2016
    Ram Year:
    n/a
    Engine:
    n/a
    Hi doug2013,
    If you decide to take your vehicle in to a dealer for diagnosis, feel free to reach out. I’m happy to assist in making an appointment or following up if needed.
    Anna
    RamCares Social Media Specialist
  8. Mineralram
    45
    522
    134
    May 20, 2015
    Ram Year:
    Engine:
    no codes, truck was shifting weird and tranny tech told right off without looking at it that it needed a shift solenoid
  9. doug2013
    146
    32
    May 30, 2016
    Georgia
    Ram Year:
    Engine:
    Little update... Unhooked the battery and hooked it back up and now the temp sensor is working I dont know if it wasn't before but i was driving my truck around for about 1.5 hours and its reading temp so that problem is solved. The trans is still not wanting to shift very well. 1-2 is fine but 2-3 and 3-4 is very delayed. normally it will shift at around 30mph from 2-3 now it wont shift until about 35-40mph. I also noticed that the mds is not kicking on at any speed or rpm even with the trans above 120 Degrees. Its also -35 out today ive noticed this only happens below -20. Does anyone know a ram guru about the 5 speeds ? this is my first mopar and i have never seen anything like this and the dealership up here is a joke.
  10. Ramunit
    Ramunit Senior Member
    816
    130
    Jun 30, 2010
    Ram Year:
    2005
    Engine:
    Sorry for the copy and paste job but I thought this would help
    545RFE Transmission Operation
    The Transmission Control Module (TCM) is programmed to allow a select variety of shift schedules that are dependent on the following physical conditions:
    · Selected gear range
    · Throttle position
    · Engine load
    · Transmission fluid temperature
    · TCM software level
    The TCM will adjust the shift schedule of the transmission as environmental and driving conditions change.
    -16°F and below and with the transmission in the Drive position, the shift sequence will be 1st to 3rd until the ATF temperature reaches -12°F. When placing the gear selector in either 1st or 2nd gear the transmission will be on 2nd gear only. There will be no torque converter lock up and switching off Overdrive will have no effect.
    -12°F and -10°F the transmission shift sequences are as follows:
    · No torque converter lock up
    · No shift in to 5th gear
    · Delayed 2-3 upshifts
    · Delayed 3-4 upshifts
    · High speed 4-2, 3-2, or 2-1 kickdown shifts are prevented
    · High throttle opening shifts will be early
    · Switching off Overdrive will prevent shifts into 4th gear
    -10°F and 36°F the transmission shift sequences are the same as above, except that 2-3 upshifts are not delayed. Switching off Overdrive will prevent shifts into 4th gear
    40°F and 80°F All shift sequences are normal except there will be no torque converter lockup. Switching off Overdrive will prevent shifts into 5th gear.
    80°F and 240°F This is normal operating fluid temperature. The 545RFE will be in the normal shift sequence, including allowing torque converter lockup.
    240°F ATF or the engine coolant 244° F, the transmission shift sequences will be as follows:
    · delayed 2-3 upshift
    · delayed 3-4 upshift
    · 3rd gear FEMCC from 30-40 MPH
    · 3rd gear PEMCC above 35 MPH
    · Above 25 MPH the torque converter will not unlock unless the throttle is closed or if a wide open throttle, 2nd gear PEMCC to 1 kickdown is made.
Share This Page
