dhay13
- Apr 12, 2015
- 3,226
- 2,822
- 2018
- 2500 6.4L Hemi 4.10's 'Off-Road'
Sorry guys I was in a whirlwind the day I posted my topic. Yes the 2500 has the 6.7 Cummins! It’s a beast! Very tall too. On a side note there’s been much conversation about the height of the side walls on the new model Ram 2500&3500. This is causing issues with 5th wheelers. Here’s what I’ve been thru;6.2 diesel??? Cummins is the 6.7L. A Grand Design 22MLE's dry weight is less than 5200lbs...and it's GRVW is 6995lbs. 8700lbs. loaded? Are you sure? You're 1700lbs. overloaded on you trailer...
Smart move on going to a 2500 to pull the 5th wheel. Your 1500 isn't optimal for towing a 5'ver. Regardless if your 5th wheel is half-ton towable....it's really not. Your pin weight of your 5th wheel and your 5th wheel hitch just ate up all your payload...
