6.1 Cam
HemiSwapped06
Euless, Texas
I think thats what I am going to start calling my custom grind cam. Its not technically a "sidewinder", because it was ordered from Comp Cams, ground to "sidewinder" specs. The specifiations include advertised duration of 265/265, 212/212 @ .050, .540/.540" lift, 114 lsa. So that IMO makes it a Comp 265.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Did your cam get bigger? These were the specs you provided for the cam page. Let me know if it needs to be updated:
Member: HemiSwapped06
Year: 2006 5.7 swap
Custom tuned 4.7 PCM SCT
1st cam Inertia Motorsports Super Spartan
2nd cam Comp Cams special grind to Sidewinder spec
Duration: Intake 212* Exhaust 212*
Lift: Intake .525 Exhaust .525
Lsa: 114
HemiSwapped06
Euless, Texas
Year: 2006 5.7 swap
Lsa: 114
Nope not bigger, just using a different specification.
Sidewinder cam
Duration @ .006" = Intake 265* Exhaust 265*
Duration @ .050" = Intake 212* Exhaust 212*
Lift = .525 or .540" depending on who you believe for rocker ratio (at first I believed Comp, but Sam and Stu have convinced me otherwise, so I list it as .540" now).
LSA = 114*
ICL = 110*
Here is a Comp 260H-13
Duration @ .006" = Intake 260* Exhaust 264*
Duration @ .050" = Intake 208* Exhaust 212*
Lift = .522/.525
LSA=113*
ICL=113*
Here is a Comp 268H-13
Duration @ .006" = Intake 268* Exhaust 272*
Duration @ .050" = Intake 216* Exhaust 220*
Lift = .528/.531
LSA=113*
ICL=113*
Comp had a line of of RV/Towing cams that included the 265 DEH grind, it measured 265* @ .006 on the intake lobe, that is where I thought of it from. 264 vs. 265 who cares.
